mill down the piston
Old Nov 22, 2008 | 04:27 AM
anton_'s Avatar
Icon2 mill down the piston
hello.
i lifted the cylinder head just to se how the pistons were doing after a summer, i bought the wrong pistons, i got b18 pistons instead of b16, i got 7,8-8,0 in comp.
i could go with 21 degrees at 20 psi and 8500 rpm and making 360 whp
i had to use a comtic headgasket .04 thick because the piston was out of the hole a little bit.
what do you think, should i buy a cometic again or should i mill the pistons own a little bit, so they dont stick out of the cylinder.
Old Nov 22, 2008 | 05:04 AM
DaveF's Avatar
it would be less time consuming to just throw another gasket on there.
Old Nov 22, 2008 | 05:06 AM
yakuza's Avatar
Or get new set of pistons and the right ones this time and while at it you might want to get 9:1 CR pistons. Help you obtain that 360hp at less boost.
Old Nov 22, 2008 | 05:59 AM
onefstek's Avatar
you have a few options.
thicker head gasket
mill the pistons
mill and bore the big end of the rods
Old Nov 22, 2008 | 06:39 AM
Turbo-LS's Avatar
How much are they coming out of the top of the block? I purchased ls piston/rods but for some reason i got gsr's. they come up out of the block but only a third of the thickness of the headgasket so clearence hasnt been an issue and it bumped my compression up higher which i liked..
Bring the piston to TDC and measure how much your piston is out of the hole and go from there. other than that i see no need to tear down the bottom end when there are different thickness gaskets to be had
I believe mine stuck out .018 and stock gasket is somethign like .028 or 0.30. Dave correct me on that if im wrong
Old Nov 22, 2008 | 07:25 AM
DaveF's Avatar
i belive the oem gasket thickness is 37 tho. and piston to head called for 45 thou. dont quote me on that though. lol
Old Nov 22, 2008 | 10:05 AM
anton_'s Avatar
hard to messure, but i came up with 0.01" when i tilt the piston against the cylinder wall and messure were the piston is most out of the block,
Old Nov 22, 2008 | 11:58 AM
matt k's Avatar
all the shelf pistons have the same pin hight 12.1 9.1 it dosent matter b18c/b16a/b18a they are all the same pin height i know all the je pistons stick out of the hole on a b16 i use a 51tho head gasket and call it a day
Old Nov 22, 2008 | 12:16 PM
yakuza's Avatar
OEM HG thickness is 0.030 ...
Old Nov 22, 2008 | 03:09 PM
HiProfile's Avatar
Those are Wiseco pistons, and they use the same piston part # for b16/b18b/b18c motors. The compression is just different based on stroke and head. Unfortunately, they require a .040" thick HG due to having one-size-fits-all pistons (that's why they're relatively cheap).
You could mill them down, since there's more than enough material to remove just .010" to run the stock HG safely. I wouldn't worry about valve reliefs unless you run huge cam lobes. I would be very careful how they get clamped down when they get milled. They are very sensitive due to such small clearances. They also have sloped skirts, which means using a lathe requires a incredibly delicate touch.
Old Nov 25, 2008 | 03:50 AM
UK Accord's Avatar
Both sets of Wiseco Pistons I have had for my F22 Z2 have sat 1mm out of the deck.
Both sets I milled down 1mm and had no issues.
95skunkedgsr
Feb 28, 2010 09:17 AM
x8_andrew_8x
10
May 7, 2007 09:35 PM
[G]
Jul 31, 2003 05:58 PM
Benny Z
Dec 20, 2002 03:35 AM
Integra91LS
Mar 30, 2002 08:49 PM
