mf2 from f-max?
Old Dec 17, 2001 | 04:13 PM
joe pagolac's Avatar
New User
Default mf2 from f-max?
i wanna know if its ok to run the mf2 with the f-max kit on an itr with 8or 9 lbs of boost with the thicker head gasket without worrying about detonation. thanks
Old Dec 17, 2001 | 07:10 PM
JM Performance's Avatar
Default Re: mf2 from f-max? (joe pagolac)
the mf2 is all about proper tuning. dont tune it and you got a good chance of ******* **** up.....tune it right on a dyno and its supposed to be a great device.
Old Dec 18, 2001 | 08:23 AM
rtype11's Avatar
Did you wnat to run it with additional injectors or as the water mist pump driver???
in either case it is a good system but I would suggest you use is for additional fuel, you will not need any adjustments untill about 3-4 psi.
Old Dec 18, 2001 | 03:14 PM
New User
Default Re: mf2 from f-max? (rtype11)
i was planning to use mf2 with additional injectors. i thought that the mf2 doesn't need to be tuned, and that its already tuned.
Old Dec 18, 2001 | 04:24 PM
If your talking about getting it from F-Max, then yeah its tuned to a general map. But for it to be reliable, safe, and strong, you really should get on a dyno.
adubaz7
Sep 14, 2007 01:07 PM
hdsupercrewf150
Honda S2000
34
Jun 23, 2007 07:51 PM
Type-X
Dec 8, 2006 11:00 AM
DOHCarp
Aug 23, 2003 04:17 PM
Arturbo
Feb 20, 2003 04:19 AM
