mbc or ebc?
Old Nov 24, 2008 | 03:59 PM
VTEC_PRODUCTION's Avatar
Default mbc or ebc?
im thinking about getting a manual boost controller but im also open to getting the electronic boost controller. im guessing its just a matter of preference but i would like to know the pro's and cons of both along with some reccomendations. i was looking at the hallman manual boost controller and also the apexi avcr EBC but any input from the community would be great. thanks guys
Old Nov 24, 2008 | 04:07 PM
93turbo16's Avatar
What engine management are you using?
I would go with a boost solenoid that is controlled directly by the ecu.
IMO you can't beat it. It is cheap and can do everything a EBC can do.
Old Nov 24, 2008 | 04:34 PM
HiProfile's Avatar
If you can get traction in 1st gear with your target boost/power level, an EBC is kinda pointless. Some MBC's can result in boost drop, creep, or odd spikes when the WG opens. EBC's will eliminate those, assuming it's set up correctly.
One nice thing about EBC's is gear-based boost, so you aren't spinning in 1st/2nd, and have tons of power in higher gears. This allows you to run for example: 7psi in 1st, 10psi in 2nd, 15psi in 3rd, and 20psi in 4th/5th. How many Hondas do you know could go WOT in 1st and not spin with 20psi??
Given how visual the options are on the EMS-based EBC's, IMO they are the way to go. S300, Neptune, and eCtune all allow this built-in with their software.
Old Nov 24, 2008 | 04:43 PM
almostboostedgsr's Avatar
Hondata boost soleniod or a high quaility EBC FTW/
Old Nov 24, 2008 | 04:47 PM
mtber's Avatar
+2
Hondata, Neptune, eCtune etc..
Old Nov 25, 2008 | 03:42 AM
smoovy's Avatar
I guess I'm old school with it. I'm using the apexi AVCR. it has boost by gear, boost by speed, boost by RPM, and scrabble boost on tap. I like it but not very user friendly if you want to use all those features.
Old Nov 25, 2008 | 03:52 AM
black_EM1's Avatar
Community Builder
Community Influencer
Gear based boost is really the major selling point for EBCs.
Old Nov 25, 2008 | 04:33 PM
i agree with you on this...im actually going with the aem ems and just pick up a boost solenoid from pherable or someplace else, maybe egay...
Old Nov 25, 2008 | 06:09 PM
i see that i can control the a/f ratio from this also but as far as the parts go im unsure as to what to buy. can anyone help me with this?
Old Nov 25, 2008 | 06:17 PM
HiProfile's Avatar
Pronouns can be deadly when there's no clear antecedent "What" are you refering too?
BTW I really wouldn't recommend AEM unless you need the coil-on-plug and crank trigger stuff that all-out 700whp+ racers sometimes use. For other cars its worth it, but doller per feature, it is not the best system for Hondas.
Old Nov 25, 2008 | 06:53 PM
im talking about controlling the a/f ratio from the aem ems. i want to know what parts i need or if im going to have to buy the whole system with the gauge and sensor. and i would use the s300 if i was tuning my integra but as for recently i left my teg and went STI
Old Nov 26, 2008 | 07:35 PM
anyone?
Old Nov 26, 2008 | 08:02 PM
mtber's Avatar
You will need a wideband oxygen sensor gauge along with a boost solenoid for aem ems.
Old Nov 26, 2008 | 08:08 PM
SovXietday's Avatar
Wow, really? Please tell me you're not tuning this car yourself.
You will need a solenoid and you will need to wire it into the ECU as per AEM's instructions.
Old Nov 26, 2008 | 11:36 PM
what? what are you talking about? yes i will be tuning this car myself. i have no idea what a solenoid has to do with anything when im talking about a/f ratio control...
Old Nov 27, 2008 | 07:37 AM
jarvis199's Avatar
im lost... so we were talking abuot boost controllers howd we get on afr?
Old Nov 30, 2008 | 03:44 PM
it was boost controllers but it changed over to a/f
Professor_X
May 9, 2011 07:53 PM
rice a roni
Nov 20, 2006 06:17 AM
97turboteg
Apr 11, 2006 10:47 PM
Racerage1
Mar 31, 2004 01:05 AM
blufke
Nov 3, 2002 05:42 PM
