MBC diagram for install??
Old Jul 22, 2008 | 04:01 PM
VTECth1s's Avatar
Default MBC diagram for install??
I've read that there's different ways to connecting an MBC. This is a quick diagram I made of what I assume the MBC would be hooked up. The MBC I chose to use was either a Hallman or Turbo XS.
1. /\/\ Is initially how I assume it would be hooked up, or vice versa; bottom port goes to IM, side port goes to WG ??
2. One port is T'ed into the vacuum hose of the WG. And the other port T'ed into the vacuum hose of the BOV ??
This is from what I've read that people have done as well.
3. One port is T'ed into the vac hose of the WG. And the other port routed to the vacuum manifold ?? Also read people doing the same.
If all wrong how should I have it hooked up correctly. For reference I'm using is a T3/T04e 57 trim, .63a/r turbo .
Modified by VTECth1s at 5:08 PM 7/22/2008
Old Jul 22, 2008 | 04:18 PM
H.A.R.T B18C1EG6's Avatar
Default Re: MBC diagram for install?? (VTECth1s)
on my vacuum mani, i have a source from the mani to the bottom port and the side port goes to the side of the wastegate.
Old Jul 22, 2008 | 04:28 PM
VTECth1s's Avatar
Default Re: MBC diagram for install?? (H.A.R.T B18C1EG6)
So I was correct then.
I assume you just ran a separate vac hose from the vac mani to the MBC. Rather then T'ing it into the vac hose for the WG?
Old Jul 22, 2008 | 04:34 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECth1s &raquo;</TD></TR><TR><TD CLASS="quote"> So I was correct then.
I assume you just ran a separate vac hose from the vac mani to the MBC. Rather then T'ing it into the vac hose for the WG?</TD></TR></TABLE>
yes sir. the mbc has its own source
Old Jul 22, 2008 | 04:43 PM
VTECth1s's Avatar
Thanks,
Old Jul 22, 2008 | 06:57 PM
delhondasol6's Avatar
nice simple writeup that will help less knowledgable... i like your drawing skillz
Old Jul 22, 2008 | 09:54 PM
VTECth1s's Avatar
Default Re: (delhondasol6)
haha, Thanks! took about 3 mins on mspaint.
Old Jul 22, 2008 | 10:52 PM
South Bay Surfer's Avatar
From: South Bay, Torrance/Carson, CA, United States
Check this website out. It was really helpful in helping me install my MBC: http://www.turbosmartonline.co...loads
Smashback
Mar 12, 2013 02:31 PM
19_HaTcH_92
Feb 20, 2010 03:24 PM
Mario.
Oct 5, 2004 03:12 PM
B18 CYA
Aug 5, 2004 10:01 PM
kholmes
May 7, 2004 11:34 AM
