maybe a dumb question...
Old Feb 11, 2006 | 01:35 PM
quik sol's Avatar
Default maybe a dumb question...
Ok I am fabricating my own turbo setup, and will be using uberdata for engine management. I won't be tuning myself, since I don't feel comfortable with the idea of doing it. I am only looking for about 250-300whp at the most on my b16, and was curious if when tuning are cam gears needed?
Old Feb 11, 2006 | 02:07 PM
InDub's Avatar
Default Re: maybe a dumb question... (quik sol)
Cam gears are definately a good investment to have. On some engines they are good for quite a bit of power and some just like being set at 0. I would recommend getting them and your tuner will be able to see if he wants to adjust them!
Good Luck
Old Feb 11, 2006 | 02:33 PM
spoon95eg's Avatar
B A N N E D
From: Orange County / Palm Springs 714/76hoe, ca, usa
Default Re: maybe a dumb question... (InDub)
Not trying to argue here but I think stock cam gears would be the best cuz aftermarket camgears tend to slip and chaarannnn vent valves yehey but it up to u
Old Feb 11, 2006 | 02:42 PM
SovXietday's Avatar
Default Re: maybe a dumb question... (spoon95eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoon95eg &raquo;</TD></TR><TR><TD CLASS="quote">Not trying to argue here but I think stock cam gears would be the best cuz aftermarket camgears tend to slip and chaarannnn vent valves yehey but it up to u</TD></TR></TABLE>
How can anyone take you seriously when they can't understand what you just typed.
Cam gears would be a good idea, you just want to make sure to get ones like Skunk2 that have 6 bolts over cheaper ones that have say 3. My venom has 4, and I've never had issues with it (SOHC). They allow you to work with the timing of your cams which is something that uberdata will never be able to touch.
Old Feb 11, 2006 | 03:08 PM
crxhybrid1320's Avatar
Default Re: maybe a dumb question... (SovXietday)
I run can gears but get ones that have al least 4 bolts to hold them in place. I think the aem ones only have 3 bolts. My Golden eagle ones have 4 bolts and some have 6 i think. I would recommend to torque them to specs and use lock-tite also to be on the safe side.
Old Feb 11, 2006 | 03:59 PM
marmo's Avatar
Default Re: maybe a dumb question... (crxhybrid1320)
Golden eagle's are top notch
Old Feb 11, 2006 | 04:29 PM
InDub's Avatar
Default Re: maybe a dumb question... (monkey marmot)
just make sure you check them.. and I use the skunk2 six bolt.
I check my everytime I change plugs, or oil
Old Feb 15, 2006 | 03:39 AM
quik sol's Avatar
If I end up running them I will run the skunk2's
Old Feb 15, 2006 | 03:57 AM
Group Tenacity's Avatar
Default Re: (quik sol)
Cam gears are not needed. We make well over 650 whp on our car and we do not adjust the cam timing at all. I have had Skunk2 cam gears slip on the intake side and bend some valves before, anything is possible even with parts that are considered high quality. When racing, anything can happen even with top $ parts.
Mike...
Old Feb 15, 2006 | 06:03 PM
quik sol's Avatar
well now ya got me thinking. I think as soon as I figure out whose tuning the car, I will take the tuners advice. Might as well make it as best I can for how that person tunes.
rdssk8rcs1
Nov 20, 2007 08:29 AM
layedoutat0psi
11
Nov 11, 2007 10:20 PM
ironchef25
22
Feb 12, 2004 12:05 PM
roadawg
44
Feb 11, 2004 08:59 AM
SohcPower93
Sep 5, 2003 01:00 AM
