dsm injectors in H22
Old Feb 15, 2006 | 09:47 AM
efiv5lude's Avatar
Default dsm injectors in H22
Im going to turbo my 5th gen prelude and i need bigger injectors. Ive seen dsm 450 injectors on civics and integras and was wondering if anyone has put them on a H22. Planning to run 6 lbs, any suggestions will be helpful.
Old Feb 15, 2006 | 10:27 AM
boosted94cx's Avatar
* B A N N E D *
h22 injectors go in the same as any b-series...but with obd1 h22 setups you're alrleady ready for low z injectors, so they're even easier to deal with
Old Feb 15, 2006 | 10:30 AM
93preludes's Avatar
Default Re: (s13-t)
you'll need a resistor box for your 5th gen but other than that they'll work great. if you can, get them cleaned before you put them in...
Old Feb 15, 2006 | 10:54 AM
mike1114's Avatar
Default Re: (93preludes)
You'll also probably max them out pretty quickly as around 300ish horses is where they seem to max. (I made 311 and almost maxed them out on a B series)
Shameless plug.....I have a set of 450C DSM's if you interested.
Old Feb 15, 2006 | 10:57 AM
93preludes's Avatar
Default Re: (mike1114)
yeah his 6lbs wont net him 300 unless he's like on a big *** turbo or something heh... 450's should do the job for you. if you're planning for alot more than 300 then consider upgrading.
Old Feb 15, 2006 | 11:13 AM
D@nnY's Avatar
I wouldnt even push 300 on dsm 450s
Old Feb 15, 2006 | 03:41 PM
TheShodan's Avatar
Moderator
Default Re: (D@nnY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D@nnY &raquo;</TD></TR><TR><TD CLASS="quote">I wouldnt even push 300 on dsm 450s</TD></TR></TABLE>
Nor would I, and I own both a DSM and a Honda..
Old Feb 15, 2006 | 06:07 PM
efiv5lude's Avatar
Will i need to get new seals and modify them the same as b series, and also will the clips work or will i need different ones?
Old Feb 15, 2006 | 06:18 PM
evilone's Avatar
Default Re: (efiv5lude)
for 300plus whp you might consider evo8 injectors(550cc)
Old Feb 15, 2006 | 06:20 PM
evilone's Avatar
Default Re: (prostock)
you can usually find them for around 100 to 150 bucks
RACEPAK
Jun 23, 2014 05:02 AM
eruktion
12
Jul 1, 2010 12:24 AM
h22prelude99
Sep 16, 2007 04:36 AM
crazyslowhatch
Sep 27, 2004 03:40 PM
