this may sound crazy.... but
Old Dec 12, 2002 | 07:02 PM
servion's Avatar
Default this may sound crazy.... but
Can you put an h22a crank in a b18c? I've been talking to someone who's claimed to have done it successfully... any thoughts?
Old Dec 12, 2002 | 07:11 PM
HotRodTeg's Avatar
Default Re: this may sound crazy.... but (servion)
I belive that the H22 cranks are longer then the b18c. If you did this you would have to relocate the jurnals on the block. I think it would be point less
Old Dec 12, 2002 | 08:37 PM
BudaKai's Avatar
Default Re: this may sound crazy.... but (streetracer)
That wouldn't be pointl-less, just inpractical. If the rods and pistons were still at the same angle if would work very nicely indeed. With that stroke and such a large beefy crank it would be quite a stump-puller. Not to mention that a longer crank would be more stable with higher rpms due to the larger bearing area. I can see why it would be in-feasible due to cost and the amount work involved to get it to work. You'd be redesigning the B-block from the bearings up.
Old Dec 13, 2002 | 09:01 AM
servion's Avatar
anyone other thoughts? this is an interesting idea...
Old Dec 13, 2002 | 09:24 AM
highbrid's Avatar
for the cost you could get a custom eagle crank, and build a bad *** deck plate motor. Just a thought
HyperFlow
Aug 3, 2010 06:08 PM
kent876
Honda S2000
May 9, 2010 10:17 PM
EthanR
Jan 18, 2010 05:30 PM
cherryhatch00
Jan 15, 2007 02:57 PM
hondahippy
May 5, 2006 11:50 AM
