Maximum shaft play on t3 turbo?
I got a free t3 turbo (garrett) and I was wondering what the maximum shaftplay should be if I am going to use it..It has around .001~ shaftplay, just a littlebit but more than enough to notice.
thanks
stephen
thanks
stephen
Re: Maximum shaft play on t3 turbo? (pythoner)
Turbos are supposed to have a bit of shaftplay. Its the seals that you have to look at. You can have a fairly unbalanced turbo, and still have good seals. Usually if the turbo doesn't 'scream' from a combo of an unbalanced shaft and sideplay, its okay.
And for ~$175 for VSR balancing, its almost better to get a brand new T3.
I know that they are soposed to have shaftplay, but this one has a little more than a new one...and no end play
I guess its not bad for free
Re: (pythoner)
As previously posted, a turbo will have shaft play, especially if there are ball bearings. If there was no play it probably wouldn't spin and that would not be a good thing. But if you're really concerned just take it to a tuner in your area and have them a good look over, they should be able to do look at it for free.
racinskittle
06-28-2003 03:19 PM
