Max-Rev users?
Old Aug 4, 2003 | 04:52 PM
Infinity_Racer's Avatar
Default Max-Rev users?
I've been trying to find the bolt sizes for the t3 flange on my manifold...I read on here that its a 3/8x24 but i cant get those bolts to go in...I tried the 3/8x16, and that goes in a little bit...I've tried all sorts of bolts but none will bite wit the thread and i dont want to force it and end up messing it up...could it be possible that the flange is backwards?
Old Aug 4, 2003 | 05:44 PM
Default Re: Max-Rev users? (Infinity_Racer)
i really think my flange is backwards after looking at it real close...my flange is really smooth where the holes are doesnt have a "dimple" like this on my wastegate flange: (notice the "dimple" curvature around the hole?)
This is my T3 flange completely smooth with no "dimples" around the holes:
Now this is T3 flange inside the manifold that has the little "dimple" part like that of the wastegate flange:
Is there anything i can do to make use of this manifold? Cut the flange out and turn it over and have it re-welded? Or drill new holes and tap a new thread in?
Old Aug 4, 2003 | 06:09 PM
ladysman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Infinity_Racer &raquo;</TD></TR><TR><TD CLASS="quote">I've been trying to find the bolt sizes for the t3 flange on my manifold...I read on here that its a 3/8x24 but i cant get those bolts to go in...I tried the 3/8x16, and that goes in a little bit...I've tried all sorts of bolts but none will bite wit the thread and i dont want to force it and end up messing it up...could it be possible that the flange is backwards? </TD></TR></TABLE>
I swore it was the 3/8x16.
Old Aug 4, 2003 | 06:32 PM
Default Re: Max-Rev users? (ladysman)
yea the 3/8x16 fits a little bit, but only goes like 1/8 of the way...i just dont want to force it in...
Old Aug 4, 2003 | 08:56 PM
bump before bed
Old Aug 4, 2003 | 09:05 PM
Full-Race Javier's Avatar
try chasing the threads with a tap.
Old Aug 4, 2003 | 09:28 PM
ffgeon's Avatar
Default Re: Max-Rev users? (javierb14)
you dont want to cut the flange off dude. trust me. just get a tap, and put a little motor oil on it for lube. then thread it into each hole only rotatingit about half a turn then turning it backwards to break the chip (if there is any). that should do ya.
Old Aug 5, 2003 | 03:48 AM
Default Re: Max-Rev users? (ffgeon)
ok thanks, i'll try to do that today and report back
Old Aug 5, 2003 | 06:29 AM
Overblown-Teg's Avatar
YEAH IT won't matter what way your flange is on.
Old Aug 5, 2003 | 12:30 PM
krazy's Avatar
Default Re: Max-Rev users? (Overblown-Teg)
i remember they were coarse thread. fine thread wont fit.
krazy
Old Aug 5, 2003 | 01:39 PM
Default Re: Max-Rev users? (krazy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krazy &raquo;</TD></TR><TR><TD CLASS="quote">i remember they were coarse thread. fine thread wont fit.
krazy</TD></TR></TABLE>
see everyone told me fine thread...my dad just came home and had a tap kit with him so we just re-tapped it and are using 3/8 x 16 now...are there certain types of bolts that i should use? you guys think i should use studs instead of bolts to support the turbo? /
Old Aug 5, 2003 | 03:54 PM
ffgeon's Avatar
studs are good. i personally use bolts, but then agian, we dont tap our turbine flanges.
Old Aug 5, 2003 | 03:55 PM
ffgeon's Avatar
before javier can say it.........use anti seize!!!! lol
Old Aug 5, 2003 | 04:37 PM
so you think bolts are fine? any specific type? we only chased the tap on the flange of the manifold, not the turbine flange...
EK FLY
Oct 27, 2005 05:58 PM
brent_G
Aug 22, 2005 01:55 PM
phatrick2332
Mar 11, 2005 09:17 PM
99silprelude
Aug 24, 2004 11:51 AM
d98clturbo
Dec 27, 2003 09:39 PM
