max rev dp question????
Old May 20, 2004 | 03:23 PM
boost fed ls's Avatar
Default max rev dp question????
people using max rev dp, what did you use(gasket,ect) between the dp flange and the cat(or test pipe in my case). It keeps leaking from that spot. Another question, should you use the stock bolt(using the spring) or just use a stright bolt, thanks!
Old May 20, 2004 | 03:49 PM
incogNitto's Avatar
Default Re: max rev dp question???? (boost fed ls)
I used RTV at first then I switched to a gasket from http://www.kteller.com. I also used straight bolts because there was already a flex section on my downpipe.
Old May 20, 2004 | 05:25 PM
J337_UNIT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boost fed ls &raquo;</TD></TR><TR><TD CLASS="quote">people using max rev dp, what did you use(gasket,ect) between the dp flange and the cat(or test pipe in my case). It keeps leaking from that spot. Another question, should you use the stock bolt(using the spring) or just use a stright bolt, thanks!</TD></TR></TABLE>
Either you can use RTV as stated above or get a real gasket
092eg6
Welding / Fabrication
10
Jan 14, 2011 08:21 AM
huge230
11
May 27, 2006 03:55 PM
1SlowSi
Feb 5, 2005 02:27 PM
RACEPAK
16
Aug 19, 2004 04:36 PM
