Max boost on stock LS rods?
Old May 9, 2002 | 11:51 AM
gigantor's Avatar
Default Max boost on stock LS rods?
Running 8.5:1 Wiseco pistons.
Anyone?
Old May 9, 2002 | 12:07 PM
Jared's Avatar
Default Re: Max boost on stock LS rods? (gigantor)
Depends on the charger and what kind of tuning you're capable of. I've seen a turbo single cam that made 300hp using LS rods. My stock LS took 9psi for a long while from a T3. It's in the tuning.
Old May 9, 2002 | 12:12 PM
gigantor's Avatar
Default Re: Max boost on stock LS rods? (Jared)
I was running 14psi on the stock bottom end. But an accidental boost spike ended the piston lands.
Before she blew I was pushing 272 whp with 11.8:1 a/f ratio.
Old May 9, 2002 | 12:19 PM
BlowOff's Avatar
New User
Will you be boaring and sleeving(sp?) the block, and/or installing a block guard?
Old May 9, 2002 | 12:35 PM
gigantor's Avatar
Default Re: Max boost on stock LS rods? (BlowOff)
Here's the buildup:
-wiseco 8.5:1 pistons (ultra-lite race version) .20 over
-Mr. Gasket head, intake manifold and exhaust manifold gaskets
-ARP head studs
The block has been cleaned, decked and bored .20 over. I had all the bearings replaced, the oil pump rebuilt, timing belt and water pump replaced and had the crank cleaned and rebalanced.
My car runs the following setup:
drag gen 3 turbo, deltagate, rc 310cc injectors, walbro 255lph fuel pump. my car is currently set at 14psi.
Old May 9, 2002 | 12:42 PM
modvp's Avatar
Do you remember how much of a boost spike occured before you blew a piston?
How long were you boosting at 14psi?
Old May 9, 2002 | 12:50 PM
gigantor's Avatar
Default Re: Max boost on stock LS rods? (modvp)
around 25psi
I ran the 14psi for a few weeks with no problems. Not even a hint of blowby.
Old May 9, 2002 | 12:51 PM
DIRep972's Avatar
Smarter than you
Ive heard as much as 350whp.. but there are always freak motors and freak set ups.. just curious, why did u go with 8.5:1 pistons? are u planning on running high boost on pump gas?
Old May 9, 2002 | 12:55 PM
Finest's Avatar
Default Re: Max boost on stock LS rods? (DIRep972)
I wouldn't even chance it with the stock rods. You're almost 90% built...why not just wait and get some GE rods or something? With that much money invested already, I would definitely wait for some rods.
Old May 9, 2002 | 04:42 PM
BlowOff's Avatar
New User
Default Re: Max boost on stock LS rods? (Prelude_RCR)
Hate to say it, but I think he's right. That's why I ended up doing it all at one time. I figured do it right the first time...so there is no next time.
Good luck with the build. Who's doing it?
Nisif
Aug 30, 2012 09:55 AM
GEN2 LS
Oct 11, 2007 07:32 AM
hotimportcrx
Sep 4, 2005 09:44 PM
silverEG6
Dec 30, 2004 06:30 PM
swpdb16
Dec 9, 2002 08:05 PM
