Max Boost/Power output on B18C5?
Old Nov 12, 2002 | 07:38 AM
01ITR#700's Avatar
Default Max Boost/Power output on B18C5?
I know this has generally been beaten to death but I just wanted to make sure I wasn't pushing my luck with my Type R. Right now I'm putting down 282whp & 198 ft. lbs. torque. I have promised to post my dyno chart but my roommates scanner took a **** on us unforrtunately. It will be up soon I hope. I'm making those #'s on 7 pounds of boost through a Turbonetics 60-1 HIFI turbo. Completely stock block, stock everything, 12:1 FMU and an Inline pump. I bolted on the custom turbo kit and threw it on the dyno as is, untunned. I ran 93 Octane pump gas, and a 2.5" open downpipe.
My question: Is the stock bottem end etc. capable of holding up to around 8psi, and hopefully around 300whp? This will still be on the stock ECU, no standalone, just adding bigger injectors, and a 6:1 FMU disk (along with the extra psi or two of boost)
Thanks, and I hope that made sense.
M
Old Nov 12, 2002 | 07:46 AM
PM-Performance's Avatar
Default Re: Max Boost/Power output on B18C5? (01ITR#700)
the guys at inline pro have told me they have tuned type r's for 12psi for the street already , anytthing is possible. im tuning mine for 10psi for the track and 8psi for the street.
Old Nov 12, 2002 | 09:07 AM
Type-ARR's Avatar
Default Re: Max Boost/Power output on B18C5? (itr206)
They weren't lieing when they told you that...
99lspwr
Nov 11, 2005 10:40 PM
acuragtr
Jul 4, 2005 09:15 AM
nate951
Oct 4, 2004 11:29 AM
Rah Rah
Feb 24, 2003 06:03 PM
99civicdx
Jun 27, 2002 02:27 PM
