map voltage and afc hack
Old May 12, 2003 | 05:58 PM
rrei's Avatar
Default map voltage and afc hack
can someone tell me what voltage the ecu will see after installing an afc at around -30 percent, at idle before and after the afc please
Old May 12, 2003 | 08:02 PM
ion_four's Avatar
Default Re: map voltage and afc hack (rrei)
why are you asking? whatever the voltage is before the afc, subtract 30%...I believe idle is 1.7v from the MAP, or I could be talking out my ***...it's 2.8v FROM THE MAP with "Key-On" ie. the engine not running, I know that...
Old May 13, 2003 | 08:36 AM
rrei's Avatar
Default Re: map voltage and afc hack (ion_four)
cause i had a bad map before , but im sure i saw 3.8 in and 3.8 out with the key in the on position. now if i switch how it should be wired ( normal way yellow to ecu white to sensor) if i switch that i get 3.8 in and 2.8 out all with the ket on , but the sensor check in the afc reads 2.8 with key on
Old May 13, 2003 | 12:42 PM
rrei's Avatar
ok i checked the voltage again. with the key in the on position its 2.8 in 2.8 out, when the car is running its .6in and .8 out does this seem right if i switch the wires around its 1.7 in 1.7 out
Old May 13, 2003 | 07:31 PM
rrei's Avatar
ttt
boostedcivicsir
Jul 24, 2007 11:49 AM
boostedcivicsir
Jul 24, 2007 06:17 AM
Running925
Nov 14, 2006 07:57 AM
VRD^don
Oct 11, 2004 04:31 PM
VTC_CiViC
Apr 12, 2004 06:00 AM
