map sensor code after run to full boost; using MSD 3 bar sensor
Old May 7, 2006 | 11:46 AM
model x's Avatar
Default map sensor code after run to full boost; using MSD 3 bar sensor
Car works perfect until you make a hard run and then I get a map sensor code and the car will stall and the a/f ratios get really lean. I just installed a 3 bar MSD map sensor.
Car is gated for 8psi.
Any ideas?
Old May 7, 2006 | 11:48 AM
coneheadsracing's Avatar
Default Re: map sensor code after run to full boost; using MSD 3 bar sensor (model x)
what program are you running? If your only gonna boost 8 psi, just keep the stock in.
Old May 7, 2006 | 12:01 PM
model x's Avatar
Default Re: map sensor code after run to full boost; using MSD 3 bar sensor (coneheadsracing)
we're using BRE 2.0
everything is going great, and the a/f's are bang on low 12's, but after a quick run, the CEL comes up, and the mixture leans way out. the car will stall, and seems to go back to normal after restarting.
we're using the 3bar because today is supposed to be "up the boost" day.
Old May 8, 2006 | 11:12 AM
Drummerboy's Avatar
small update...
the car is still leaning waay out after a pull through a gear or two, and resets after restarting. we did manage to wideband tune the car for 12psi, and it drives perfectly, until the map freaks out. so it's not the tune...
however, the dash CEL is staying on all the time now.
i tried another new sensor this morning, and same thing. so it's probably somewhere else. still getting the map sensor code though, and also code 7 (tps).
going to try and check things out with an ohm meter after work.
any input?
Old May 8, 2006 | 05:55 PM
Drummerboy's Avatar
Default Re: map sensor code after run to full boost; using MSD 3 bar sensor (Drummerboy)
has anyone else ever had a 3bar map, or any map sensor, freak out after a WOT pull?
Old May 9, 2006 | 07:27 PM
Drummerboy's Avatar
bump, with more info...
so the dash CEL seems to be staying on at random. sometimes i'll fire it up, the light's off, and it runs amazingly. other times, the light's on, and it drives well, but has a slight stumble every now and then. after a hard pull, it goes bananas, and i have to restart the car.
i dunno.
i just wanna get to work on time.
Old May 12, 2006 | 07:53 AM
model x's Avatar
looks like its a known problem with BRE 2.0; Ben O. said switching to v2.2 will solve this.
We'll let everyone know how it goes
Old Jul 1, 2006 | 01:54 AM
SiRocket's Avatar
either that or.... tps for sure...
teg_95
Apr 28, 2009 07:19 PM
1baddcivicsi
Sep 1, 2006 06:35 PM
kell211
Oct 7, 2003 05:39 PM
