MAP sensor + boost help.....
Old Aug 14, 2003 | 08:50 PM
80884's Avatar
Default MAP sensor + boost help.....
This is for my friends car. It's a 96 integra LS. need to run 15 psi. He got a gm 3bar. and aparently he doesn't know how to hook it up. Let me know if this is right.
Vacume line to intake manifold, and wired like this.... grd is - green/white, MAP signal - White, 5V is yellow/red.
Also he has a stock ecu, is this what he needs to be able to run over 11 psi? If not what does he need?
Old Aug 14, 2003 | 10:09 PM
11psiTurboSI's Avatar
Default Re: MAP sensor + boost help..... (80884)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 80884 &raquo;</TD></TR><TR><TD CLASS="quote">This is for my friends car. It's a 96 integra LS. need to run 15 psi. He got a gm 3bar. and aparently he doesn't know how to hook it up. Let me know if this is right.
Also he has a stock ecu, is this what he needs to be able to run over 11 psi? If not what does he need? </TD></TR></TABLE>
3bar only is good for a standalone like hondata... won't do you any good on a stock ecu... the wire diagram is on http://www.hondata.com
Old Aug 14, 2003 | 10:13 PM
80884's Avatar
Default Re: MAP sensor + boost help..... (9psiTurboSI)
So there is no way to use the stock ECU? If so please let me know.
Old Aug 14, 2003 | 10:17 PM
TEAMGENDAI's Avatar
I wouldnt run a 3 bar on a stock ecu i would purchase a hondata or go back to check valves and pump and regulator
Old Aug 14, 2003 | 10:18 PM
80884's Avatar
Default Re: MAP sensor + boost help..... (TEAMGENDAI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TEAMGENDAI &raquo;</TD></TR><TR><TD CLASS="quote">check valves and pump and regulator</TD></TR></TABLE>
So what do i need to buy. and how does it work.
Old Aug 15, 2003 | 06:34 AM
80884's Avatar
Ok he has a VAFC in his car as well. What do i need to make it boost over 11psi and run right? Do i need this missing link or the check valves?
96 integra LS turbo VAFC, stock ecu. looking for over 11 psi and for it to run good.
Rand The Man
20
Sep 18, 2013 05:32 AM
Cantcatchme
Engine Management and Tuning
Dec 25, 2011 03:54 PM
R THIS
May 2, 2008 12:55 PM
slow260z
Jul 23, 2007 05:34 AM
I B BANGGIN
Feb 6, 2007 07:50 PM
