map sensor?
Old Nov 29, 2007 | 04:11 PM
mma82's Avatar
Default map sensor?
only running 7-8psi with drag turbo kit w/3" exhaust on b18c w obd1. installer didnt have missing link so he ran check valves (4 of them, t'ed off) still picking up check engine light and reset the ecu and picking up error 01 i believe which is the map sensor?
comments and suggestions please
Old Nov 29, 2007 | 06:33 PM
xenocron's Avatar
Default Re: map sensor? (mma82)
Get the ECU chipped and have the car properly tuned. Get rid of the FMU and Check Valves and get some larger injectors.
Old Nov 29, 2007 | 06:58 PM
mtber's Avatar
Default Re: map sensor? (xenocron)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xenocron &raquo;</TD></TR><TR><TD CLASS="quote">Get the ECU chipped and have the car properly tuned. Get rid of the FMU and Check Valves and get some larger injectors. </TD></TR></TABLE>
+ A walbro fuel pump
Old Nov 29, 2007 | 07:33 PM
xenocron's Avatar
Default Re: map sensor? (mtber)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtber &raquo;</TD></TR><TR><TD CLASS="quote">
+ A walbro fuel pump </TD></TR></TABLE>
Oh yeah, but hopefully the guy that installed his kit already recommended that since he was running an FMU
Old Nov 29, 2007 | 08:44 PM
mma82's Avatar
yea i forgot to mention that i did get Walbaro fuel pump. i thought w 7-8 psi i didnt need larger injectors
Old Nov 29, 2007 | 08:50 PM
mma82's Avatar
also i forgot to mention my fuel filter has been replaced also if that makes a diff. i needed it to be changed anyway
Old Nov 29, 2007 | 10:38 PM
carrnut21's Avatar
you will defiantly need bigger injectors to be safe. DSM 450s are a cheap option and pretty easy to find
Old Nov 30, 2007 | 07:53 AM
mma82's Avatar
ok thanks i appreciate it. so that should take care of the check engine light? also as long i dont shift high then it is not harming the motor right? at about 5 rpm is when the check engine light comes on. so ive just been really easy on my car lately
nihaphan
Jan 12, 2005 04:59 AM
julio1998
May 27, 2004 05:31 PM
Blanket Jackson
May 25, 2004 07:59 PM
Pengo
Jul 30, 2002 08:43 PM
Teluan
Sep 3, 2001 07:29 PM
