map defensor..?
to the OP: This is a very bad way to run a boosted car, FMU and checkvalve setups are nothing but band-aids, in other words you are asking for trouble. I suggest using a 3bar map sensor and a chipped and tuned ECU.
Anyway heres the info you're looking for:
You hook the map sensor up to the end of the tube.
Hook the metal plate up to where your factor MAP sensor mounts, then hook the end of the tube coming off that machined plate to your map sensor and mount the map sensor somewhere (such as the firewall).
For the others:
A map defensor is nothing more than a Missing Link aka check valve.
taken from: http://www.turbounlimited.com/...d594b
<FONT SIZE="3">Map Defensor</FONT>
The Inline PRO map defensor completely eliminates map sensor trouble codes caused by boost pressure.
This is a must device for users utilizing factory ECUs.
For the others:
