map
Old Jul 6, 2004 | 09:04 PM
kook911's Avatar
Default map
well i tired to install my missing link on my h22 turbo. i had the check valves running though it. after i got it installed it started to blink a cel, so i stop right a way thinking i am misfiring. got it home and took off the missing link and check my plugs to see if i was misfiring. well the plugs are fine and i put my map sensor back on without the check valves back on, which i forgot to put back on. took it for a test drive and no cel came on at all? so what gives, do i need the check valves on or can i leave them off? thanks
Old Jul 7, 2004 | 11:39 AM
tgreaves's Avatar
Default Re: map (kook911)
Umm.. How about a little more info about your setup.. What fuel management do you have?? A check valve by itself isnt going to add fuel..
Blanket Jackson
May 25, 2004 07:59 PM
Private50
Nov 2, 2003 06:11 PM
Pengo
Jul 30, 2002 08:43 PM
filetofit
Jun 4, 2002 02:56 PM
