Manual Boost Controllers
Old Aug 13, 2002 | 03:58 PM
DLB1994's Avatar
Default Manual Boost Controllers
any one ever put a Manual Boost Controller in side the car
Old Aug 13, 2002 | 04:06 PM
Giuseppe's Avatar
Default Re: Manual Boost Controllers (DLB1994)
ive thought about it a few times
but i know keeping the lines as short as possible is beneficial
ttt, (i wanna know too dammit)
Old Aug 13, 2002 | 05:41 PM
InfamousRS's Avatar
Default Re: Manual Boost Controllers (Giuseppe)
I think with me it would just be to tempting to turn the know just a *little* bit more. At least with it under the in the engine bay you have to put a little more effort into changing boost levels so you are a little more likley to think about the consequences on your motor.
Old Aug 13, 2002 | 09:53 PM
RuthlessEF-9's Avatar
Default Re: Manual Boost Controllers (InfamousRS)
i agree with the last post
Old Aug 13, 2002 | 11:16 PM
B-Series Sol's Avatar
Default Re: Manual Boost Controllers (ruthlessSpecR)
just as tempting as it would be to have a digital boost controller inside the car. I would keep the ugly manual boost controller under the engine bay where it belongs.. if you made a nice switch, that would look good in your car... But then again, if this is an all our race car and looks dont matter then why the hell not?
Old Aug 14, 2002 | 01:03 AM
ninesecrx's Avatar
Default Re: Manual Boost Controllers (B-Series Sol)
actually it would have bad side effects. The vacum run would be too long on a normal manual boost controler. On an average, you dont want any wastegate lines to be longer then about 3-4 feet.....Mike
Old Aug 14, 2002 | 03:22 AM
DSF's Avatar
DSF
Default Re: Manual Boost Controllers (ninesecrx)
http://www.hallmanboostcontroller.com/
...they have a nice solution.
Old Aug 14, 2002 | 07:55 AM
TypeC's Avatar
Default Re: Manual Boost Controllers (DSF)
Don't do it! The lines will make the boost SPIKE like crazy. The longer the lines, the more time it takes for the boost source to reach the mbc, and the longer it takes for the boost to go from the mbc to the wg. My bc lines are SHORT as hell. Use the underhood mbc, or get an ebc. my $.02
Old Aug 14, 2002 | 08:24 AM
DSF's Avatar
DSF
Default Re: Manual Boost Controllers (Shaft TypeC)
What are talking about? Hallman's lines are the same legnth as any other MBC. They just move the "control ****" into the cabin. The MBC stays located under the hood.
Old Aug 14, 2002 | 09:41 AM
zojirushi's Avatar
dunno, i have the joe p mbc. No spike whats so ever.
Old Aug 14, 2002 | 09:44 AM
tararan's Avatar
Default Re: Manual Boost Controllers (zojirushi)
can someone post pics.....
Old Aug 14, 2002 | 09:48 AM
Giuseppe's Avatar
but is yours in cabin?
Old Aug 14, 2002 | 09:53 AM
DSF's Avatar
DSF
Default Re: Manual Boost Controllers (tararan)
Here is a pic (I hope) of Hallmans "new" MBC...
On their standard kits, the **** to adjust spring tension (they use a ball and spring design, not a bleed valve) is attached directly to the MBC. The just routed the **** itself into the cabin.
Old Aug 14, 2002 | 10:21 AM
TypeC's Avatar
I wasn't talking about that particular mbc, just mbc in general. The signal/source and actuation lines always should be as short as possible on any bc.
Old Aug 14, 2002 | 10:25 AM
DSF's Avatar
DSF
Ahh, gotcha. My bad. In that case, "you are correct, sir" (said in an Ed McMahon voice)
Old Aug 14, 2002 | 11:42 AM
Evil EG's Avatar
http://www.turbosmart.com has a mbc that you can adjust from inside the car.
Old Aug 14, 2002 | 12:03 PM
*Boostwerks*'s Avatar
i currently have the Dawes Device MBC in my setup...
I Have yet to run the car with it however (waiting for my clutch), but I have heard very good things about it...
It was only 30 something, and unlike the other MBC's it doesn't "bleed" off boost to increase...It holds the boost you set it too, and then releases it too the actuator...This will give faster spool and even help the wastegates life(it's not moving all the time).
They also sell, a Solinoid to change between the actuators set boost level (spring) and the MBC's boost level. Its controlled by a switch in the cabin.
Heres their site...
http://www.DawesDevices.com
[Modified by Bryson, 2:03 PM 8/14/2002]
Professor_X
May 9, 2011 07:53 PM
chrisgottigsr
Dec 18, 2005 05:00 PM
Racerage1
Mar 31, 2004 01:05 AM
IgniteTeg
Aug 25, 2001 05:32 AM
