manual boost controllers
Old Feb 21, 2006 | 08:05 PM
SpoolnByYou's Avatar
Default manual boost controllers
sup guys,
Was wondering,i need a manual boost controller,my blitz ssbc went out on me,or something went wrong. now im just going to get a plain old manual boost controller. i was wondering if i could just get a cheap one off ebay,since manual boost controllers really have nothing to them,or do i need to go ahead and get a named brand one like turbo xs or something. i know you get what you pay for,but really how complex is a ball and spring,with a screw to adjust it?
Old Feb 21, 2006 | 09:01 PM
Soccerking3000's Avatar
Default Re: manual boost controllers (SpoolnByYou)
i have a turbo xs high performance one and havent had a single issue with it. I dont know if an electronic one would help it spool or not but i know mine works fine
Old Feb 22, 2006 | 12:27 AM
Fallen86's Avatar
Default Re: manual boost controllers (Soccerking3000)
manual boost controllers work on a spring which open gradually until the desired pressure is reached then stops. the gradual opening causes the wastegate to also open a bit before desired boost is reached... therefore... u dont spool as fast. so theoretically that's why an electronic one is better but i've used both and i found that when u gun it it doesnt make a damn difference. unless u have a really slow turbo and a really high set psi, i guess.... cheap MBCs are fine but they spike sometimes, main problem there.
Old Feb 22, 2006 | 03:25 AM
nickromeo's Avatar
Default Re: manual boost controllers (Fallen86)
i think bleeder boost controllers work that way but not ball and spring ones, i think the spring ones the pressure needs to reach a certain level before it even thinks about moving.
but i see ur point though, it is a spring and even some pressure (if not enough to open it all the way) may cause the spring to start to compress partially, but i think that amount is negligible, imho.
for MBC definatle ball and spring is the way to go, not bleeder.
turbo XS sells both kinds, turbo smart only has ball+spring i think, i have a generic one ball spring one. (JOE. P MBc)
Old Feb 22, 2006 | 05:14 AM
bubs's Avatar
I have a homemade MBC that I made for ~$5-6 at lowes using the ball and spring technique and it has worked really well for me. I had more problems with the wastegate opening early before I added the MBC, now it opens right at my set point.
Old Feb 22, 2006 | 05:32 AM
Default Re: (bubs)
yes,all the help is appreciated,but if you read im not wondering the difference between a ball and spring vs a bleeder,nor if a ball and spring is as good as a electronic manual boost controller. read. all im wondering is if i can get away with buying a cheap one off ebay,since there is no complex design,all it is,is a ball,spring and screw you turn.
Old Feb 22, 2006 | 05:33 AM
PM-Performance's Avatar
Default Re: (bubs)
Spend the money and get a name brand one. IE Turbo XS, Hallman
I had much better experiences with Manuals .I have the XS Dual stage now and it works awesome. I can get an AVCR for like nothing right now, but I cant bring myself to get into headaches again when I have something that works well
chrisgottigsr
Dec 18, 2005 05:00 PM
SIK IN DA HED
May 17, 2002 10:44 AM
DIRep972
Nov 29, 2001 11:51 AM
