couple turbo q's
Old Sep 5, 2002 | 06:36 PM
avividmemory's Avatar
Default couple turbo q's
first, i have the deltagate w/g hooked up from boost nipple to the turbo nipple...do i need to run a vacuum off the top of the wastegate too? if so i need to find a screw or part # of the screw that taps into the vacuum spot...so if anyone knows i need help with that...
second how to hook up a manual boost controller...i place it between the line that runs from w/g to turbo then to where...vacuum?
early thanks guys
edit: also i lost the pressure screw for my blitz bov...if anyone knows what size it is...help me on that one too
[Modified by NoPowerAllRice, 10:41 PM 9/5/2002]
Old Sep 5, 2002 | 06:41 PM
speedymon's Avatar
Default Re: couple turbo q's (NoPowerAllRice)
early thanks guys
WTF??? The side port of the wg goes to a vacuum source on the IM doesn't it? The boost controller goes on the top port.
Old Sep 5, 2002 | 06:43 PM
Default Re: couple turbo q's (speedymon)
see this is what im trying to determine...the side nipple says "boost" therefore i assumed it connects to the turbo...the top says vacuum...
Old Sep 5, 2002 | 08:49 PM
Old Sep 5, 2002 | 08:59 PM
paulzy's Avatar
side port goes to either turbo ir I.M.
top port is left open unless you're running a EBC...
your MBC goes inline of the vacuum line that runs from teh side port to where you choose
Old Sep 6, 2002 | 06:19 AM
Default Re: couple turbo q's (paul_vang)
so the MBC just runs inline? w/out a vacuum source
craig88crx
Apr 20, 2008 02:30 PM
almostjdmeg
Mar 10, 2008 01:00 PM
leinadmiih00
Jan 20, 2007 04:58 PM
djnikko
Nov 28, 2003 02:11 PM
jdmtegxsi
Jan 23, 2003 08:23 PM
