Manual boost controller
Old Feb 23, 2008 | 09:48 AM
civic_turbo_wannabe's Avatar
Default Manual boost controller
Ive got this boost controller.
Ive done a crappy sketch, and i know its completley wrong! i just cant figure it out, need H T help!
Old Feb 23, 2008 | 10:12 AM
drumking15's Avatar
if you have a 2nd line coming from the intake mani its seeing the same pressure (slighty less 1-2psi) than the compressor cover....basically what you need to do...is take off the intake mani vaccum line...and run it to the atmosphere label on the MBC...and then to the top of wg
Old Feb 23, 2008 | 10:24 AM
Like this buddy? Does everyone agree? :D
Old Feb 23, 2008 | 02:32 PM
turbo boost's Avatar
Default Re: (civic_turbo_wannabe)
i dont think u use the top port with a manual BC..only a EBC..i could be wrong?
Old Feb 23, 2008 | 02:36 PM
Thats what i thought aswell... hmm
Someone clear this up for me.... please
Old Feb 24, 2008 | 08:35 AM
Thats right know aint it?
But should i have the vacuum line goining to the top WG port or not?
I dont need to use another vacuum source (intake mani) when im using the turbo housing, correct?
Old Feb 24, 2008 | 09:01 AM
vtec_killer_'s Avatar
u have to plug into the top of the wastegate for a boost controller or else u will only be boosting off of the spring rate from the wastegate.
Old Feb 24, 2008 | 09:21 AM
drumking15's Avatar
Old Feb 24, 2008 | 12:34 PM
Flashmn's Avatar
Default Re: (drumking15)
Yeah this last one looks most logical. Civic, No you dont use vacuum sources for boost control, you use boost sources.
Old Feb 25, 2008 | 02:41 AM
sohc_kuhol's Avatar
Default Re: (Flashmn)
the last pic is correct. i have the same mbc and its working superb in that formation
Old Feb 25, 2008 | 08:23 AM
Flashmn's Avatar
Default Re: (sohc_kuhol)
Yeah you're just creating a leak for the boost to escape so that the diaphragm wont get boost signal = wastegate stays shut later. The type we mostly use is the one with the spring and ball where you tighten the spring so that it wont let air to the diaphragm until a certain boost level.
Old Feb 26, 2008 | 12:27 PM
Nice, thanks guys!
Old Feb 29, 2008 | 08:57 PM
hondamn1320's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drumking15 &raquo;</TD></TR><TR><TD CLASS="quote">
i have the same MBC and i don't have that little "T" box thing. i was wondering if i could use any regular "T" fitting. would it work the same or would i have to find that specific "T"?
Old Feb 29, 2008 | 10:53 PM
HondaKyle's Avatar
Default Re: Manual boost controller (civic_turbo_wannabe)
I would not trust that AT ALL
Old Mar 1, 2008 | 09:35 PM
sohc_kuhol's Avatar
Default Re: (hondamn1320)
Actually, the tee that is included in the kit SUCKS. it makes the whole process more complicated. just use a regular tee. i threw that one away lol
Old Mar 1, 2008 | 11:59 PM
thanks
Old Apr 2, 2008 | 09:52 AM
civic92si's Avatar
what if i dont have the turbo comp housing? then what?
Old Apr 2, 2008 | 10:43 AM
Boostedb20EH2's Avatar
Default Re: (civic92si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic92si &raquo;</TD></TR><TR><TD CLASS="quote">what if i dont have the turbo comp housing? then what?</TD></TR></TABLE>
Wat
SOHC_MShue's Avatar
you can use that t, but your gonna want to remove the ball and spring from the inside of it. It uses this to aid in spoolup, but causes bad boost spikes in my experience with that boost controller.
Old Apr 2, 2008 | 11:01 AM
93supercoupe's Avatar
Default Re: Manual boost controller (SOHC_MShue)
im pretty sure u want a boost/vacuum going into the controller and then From the controler to the wastegate.
TurboCivic11
Dec 23, 2009 08:56 AM
ericstambaugh07
Apr 7, 2007 12:45 PM
1baddturbosi
Dec 3, 2006 07:11 PM
standbackimapro
May 30, 2006 05:22 AM
X2BOARD
Dec 16, 2001 10:54 PM
