making oem and rc injector clips interchangable??
searched and can't find the thread with the pic of the wire clip that someone used on the injector clips and the main wires so that you can change from rc to oem injectors by just unclipping them. anyone know the thread or do you know of a clip that will work for this?
The RC clips are merely "OBD-1 style" injector connectors. The OEM connector or clip needs to be replaced with ones that will match up to the RC injectors. You simply cut your old ones off and solder the new ones on.
Wire polarity doesnt matter, but keep it the same, just in case.
I can get you pics later if you still need them
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman »</TD></TR><TR><TD CLASS="quote">The RC clips are merely "OBD-1 style" injector connectors. The OEM connector or clip needs to be replaced with ones that will match up to the RC injectors. You simply cut your old ones off and solder the new ones on.
I can get you pics later if you still need them</TD></TR></TABLE>
i dont think thats what he needed
but to maybe answer it too....you can use the rc(obd1) style clip and if you need to swap back get some obd1 injectors.... is that out of the question?
are the injectors different, obd1 and obd2 as far as opperation(i want to know too)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pornstarSR »</TD></TR><TR><TD CLASS="quote">are the injectors different, obd1 and obd2 as far as opperation(i want to know too)</TD></TR></TABLE>
nope, they just have a different plug on them. electronically, obd1 and obd2 injectors will work with either an obd1 or obd2 ecu.
RICE POLICE SIP
Feb 13, 2010 10:01 AM
