MAC Solenoid
Old Jun 23, 2013 | 03:57 PM
CleanEm2's Avatar
Default MAC Solenoid
Looking into MAC boost control solenoids but don't know which is best or even correct to use.
Found conflicting part numbers VIA threads on here but haven't had any answers thus far.
Was looking into this solenoid- http://www.extremepsi.com/store/prod...roductid=24381
But from what I've been reading here-
https://honda-tech.com/forums/engine-management-tuning-124/truth-about-mac-boost-solenoid-2350901/
There's two other options? Another 35 series model and a 36 series model for "continuous" use. Anyone have any luck with the 35A-AAA-DDBA-1BA model? Beings that Hondata/AEM are the same exact unit; Just re-labeled, I'm sticking with MAC
Old Jun 23, 2013 | 04:46 PM
TheShodan's Avatar
Moderator
Default Re: MAC Solenoid
https://honda-tech.com/forums/showthread.php?t=2350901
You Don't. You get something like a Chrysler or other OEM Automotive solenoid which can both run on Hondata. and have the same voltage. no spike, no mess ups. OR run a manual boost controller and NEVER worry.
Old Jun 23, 2013 | 05:37 PM
CleanEm2's Avatar
No spike, no mess ups? Pretty sure MAC/AEM/Hondata all have a failsafe for this reason as well....
Run a manual boost controller and "NEVER" worry? Anything can fail, Even a manual controller. You can't run Boost by gear with a manual anyways
Old Jun 23, 2013 | 05:56 PM
TheShodan's Avatar
Moderator
heh. you wouldn't need a failsafe or issues if the damn thing worked in the first place. Look at ALL the wonderful little threads of "boost creep? Is it my manifold, my wastegate dump? what could cause this?" And yet they have the safety features in place as well.
Chrysler solenoids. Same voltage signal for hondata to read, same hook up, a small change is SManager in the default setting, and DONE. If you want to fight all day with an industrial solenoid in an automotive application, go right ahead. doing this long enough, I'll tell that the solution is in an automotive solenoid, not this bad boy. Hell, and I'm an Hour away from their headquarters.
As for BBG... well, drag racers, what can I say. It won't help you, if you can't keep stable boost pressures.
Old Jun 23, 2013 | 07:11 PM
CleanEm2's Avatar
Link
Old Jun 23, 2013 | 08:01 PM
TheShodan's Avatar
Moderator
http://www.autopartsway.com/PartList.../pagenum1/tabS
Even the Grimspeeds are better than the MAC
You can change the OEM wiring plug that the Grimmspeed uses so that you can switch connectors.
It may be subaru based, but they control higher boost pressures 10X more than most hondas will need and control quite well. the instructions will work on universal setups as well as Subarus so don't be skerrred.
How-To on the Grimmspeed
Honda people just are too afraid of other companies that work because they think its that different in terms of simple voltage.
Old Jun 23, 2013 | 09:08 PM
wantboost's Avatar
Who is Mr Robot?
So no mac solenoid then? I've got my gm solenoid laying around but I might need the mac unit to control air pressure to an assembly that controls my vgt system
Old Jun 23, 2013 | 09:27 PM
TheShodan's Avatar
Moderator
Keep what you have. there won't be any difference in switching to a MAC to control air pressure. same phenomenon, same hook up. If you're using SManager, its s simple switch to default "closed" as the blow-through works when there is voltage to it.
SpoolnG2
Feb 29, 2008 12:17 PM
Stevegunit16
Nov 7, 2007 04:58 PM
Steri
Oct 14, 2005 09:35 AM
SeOuLxK
Honda Motorcycles
32
May 24, 2005 04:38 PM
