M&W Pro-10
Old Mar 15, 2009 | 01:54 PM
j-bird20's Avatar
Default M&W Pro-10
So i got my M&W Pro-10 kit from t1. I installed it on the car and im having alittle problem. The first problem is everytime i activate 2-step,the rpms drop all the way to 0 but the car will stay idle then when i let go the rpms will go up and come back down. It will not start popping and building boost. Its really weird. Also when i turn power on, my tach goes from 0 to pegging the tach back and forth until the car is started. The car starts and idles fine.
Old Mar 15, 2009 | 02:05 PM
xenocron's Avatar
Default Re: M&W Pro-10
I believe with eCtune's launch, it kills the ignitor signal...which, with the M&W is bypassed. That might be part of the issue...
Old Mar 15, 2009 | 02:06 PM
Teglove2's Avatar
In for an answer..i also just got my M&W pro10
What car do u have?
Old Mar 15, 2009 | 02:08 PM
j-bird20's Avatar
Its 89 ef y8 motor. So im guessing that i cant use ectunes launch control anymore??
Old Mar 15, 2009 | 04:07 PM
xenocron's Avatar
Not sure...I'll talk to Calvin and then to Tony and compare notes and let you know.
Just curious why you decided to go with the PRO-10? Were you having ignition issues?
Old Mar 15, 2009 | 05:06 PM
tony1's Avatar
The tach is driven by the Pro 10 instead of the igniter now, but should still function the same as it did with the igniter. Cutting the signal to the ignitor should do the same thing as cutting the signal to the Pro 10.
I can't tell by your description, is it just the tach acting weird, or is the tach doing what the engine is doing and the engine is acting weird?
Is this a stock tach?
Old Mar 15, 2009 | 05:44 PM
Teglove2's Avatar
I know this is kind of thread jacking but Tony, if you dont mind, can u please tell me what the job of the igniter is and why the M&W box is needed? Im well aware of how to wire it in but not too sure why it does its job so well. Theres almost no install/info about the M&W box anywhere on the internet.....
Old Mar 15, 2009 | 06:24 PM
j-bird20's Avatar
no its a autometer tach. Ever since i put the M&W, thats when it started. The tach just jumps from 0 to taching out. Then when i engage launch control it just goes down to 0 on the tach and stays thier until i let off the pedal
Old Mar 17, 2009 | 05:26 AM
Teglove2's Avatar
in for an answer
Old Mar 17, 2009 | 05:59 AM
Turbo-charged's Avatar
are you getting your rpm signal for the tachometer from the tach signal output on the pro-10 box?
Old Mar 17, 2009 | 08:55 AM
j-bird20's Avatar
Yes the tach signal is going from the Pro-10 directly to the tach.
Old Mar 17, 2009 | 12:21 PM
tony1's Avatar
The reason your rpm drops to 0 on the ectune 2 step is because it's cutting the igniter signal. The igniter signal is how the Pro 10 determines RPM. Without it, it can't drive the tach. It's only a problem with ectune and an ign cut. If you can change it to fuel cut, it'll change the tach issue.
At the end of the day, it's really nothing to worry about.
Teglove, think of the igniter as a type of relay for the ign system, so the output of the ecu isn't driving a big load.
yee SERIOUS
Apr 17, 2006 01:58 PM
Crimson_Tide
Dec 19, 2005 09:29 AM
monalisa overdrive
Sep 4, 2005 10:43 PM
vinuneuro
Mar 28, 2005 11:41 PM
RS1995
Jun 8, 2002 08:17 PM
