LST / LS-T Turbo B18A B18B setups
Re: LST / LS-T Turbo B18A B18B setups
So I have been geting parts together for my set up just got a t4 single wastegate bottom mount turbo manifold spooling. Supertech valvetrain. Edelbrock victor x mani persicion 825 Hp intercooler and exospeed front end. Also my block is on the way to golden eagle for sleeves and o rings. Looking to make 800 Hp in a si coupe and 9.8 what u guys think?
They are awesome I have a buddy (actually my insurance agent) who owns one that is supercharged and the car is nasty he actually takes it out to the tx mile and does that event along with a couple of other friends of ours.
Picking up a 95 hatch tomorrow with gsr swap and some goodies bolted on, also peeped a hondata s200 laying on the floor. 800 bucks LOL
Went to dyno. Made 462whp on about 23-25psi,, then Started to Push coolant thru head gasket on a 30psi pull,, so I'll check it out better tomoro see how bad it is,
Turbo LS Dam you picking up All the Goodies man, hahah Enjoy them.
Jimmy Nice Numbers Hope you work out your HEad Gasket Issue!!
What tranny would you guys suggest, mine grenaded on my way home from work
OUCH !!!!!
GSR trans is best all around trans for all b series motors.
Got the hatch running tonight. Its pretty obvious some punk *** teenager loser kid owned it last, wiring all hacked up. Ignition switch is bad so he hacked up wiring to make the relay work and to get the car to start. Either vtec isnt working or its leaning out really bad once hits vtec. Could be some goodies inside the motor who knows though. From the looks of it could be a poormans type r build. trans is solid and has a good clutch in it. All in all a good steal at 800 bucks for sure.
ok i found a type r trans with a lsd and 4.7fd for a 1000obo is it a good deal. i plan on putting a lsd in whatever trans i get if it doesnt have one. do you guys keep all the gsr gears in it or change any of them out
Just wondering, I have a b20z fresh rebuild with stock rods and pistons. With jg 303 cams, super tech springs, ARP rod bolts, headbolts, and acl race bearings. With intake and exhaust. gonna be tuned with s-300. Roughly what do you guys think it will make for hp and tq?
Do you want to sell the trans thats in the car now ? ill buy the gearset. You dont want type r trans. way to short gear for an LS motor.
Hey guys! I never realized this thread was here.
I have an LS-T. This morning before work some rice rocket white boy pulled up next to me and downshifted to first at ~20 just so show me vtec right before a light.
So I decided it was only fair I showed him mine. Needless to say he took off like a bat out of hell at that red light. I gently accelerated through first into second, once I was caught up at ~45mph I matted second for the remaining rpm's and opened up my 40mm Tial WG at his open drivers side window.
Mind you I am running a full 3 inch thermal research exhaust so the car is whisper quiet until I hit my "vtec" at 12psi lol.
lol I ignore cars like that. Not worth the gas
Got my Walbro 400 and turned up the base pressure to 60. Dropped my duty cycle down to 80% from 115% lol. Put the old 15lb spring back in the wastegate because it just works so much better and is much easier to regulate at higher boost pressures then the 7lb spring was.
Also picked up some R888 and tried them out. Car is scary fast in 3rd gear hooking at 25lbs. 225/45/16. Trying to get back on the dyno again this week or next to dial it at higher boost.
This is the kinda poking and stretching I like lol
To be honest the scene around here is so shady and dead that it's hard to find anybody to have fun with... If it wasn't for the track having a nice honda would be pointless.
You're running e85 right? I wanna convert so bad but i'm nervous lol.
