LST / LS-T Turbo B18B's...
Well i have noticed that a lot more guys are out there boosting LS's and i thought it would be nice to have a trend to post set up's and idea/tips for US LS peeps...
so ill start... stock LS from TB to oil pan 2.5charge piping FMIC walbro 255 intank XS RFL bov Tial 40mm BMC log, dump tube and 3" DP t3t4 60trim .63 a/r turbonetics RC 440's Hondata S200 10PSI 250whp 225ft lbs 8.6@84.8mph in the 1/8th on federal tires.... 2.0 60ft.... that was open DP with no extra BS weight STOCK clutch....slippin https://honda-tech.com/forums/images...s/emthdown.gif New set up 85mm LS block RS sleeves Eagle rods CP pistons 9:5 comp 62-1 stage 5 wheel 63 trim Turbonetics 8.3@86mph on 3 cyliners with my tool box and all my work stuff with the EXHAUST (2.3") hooked up https://honda-tech.com/forums/images/smilies/emwink.gif Modified by Snoflake at 9:42 AM 10/15/2005 |
The best advice for an LS'er is:
Head work - if you ever want a useable powerband with a beefy sized turbo, head work is your best friend. Porting, cams, springs/retainers - the works. It's expensive but makes all the difference. |
Re: (DragSource)
Heres my setup:
Bone stock ls 104,000 miles SFP mainfold Tial 38mm wastegate Garrett T3/T4 57trim .63ar exhaust 2.5 in open downpipe 2" pipe off of the turbo, 2.25" to the TB Spearco intercooler Sard R2D2 BOV Fast turbo oil lines Walbro 255 fuel pump RC 550cc injectors Hondata S200B Greddy profec B spec II Excedy 3 puck clutch Tuning was done at 10psi. See sig for dyno graph Dont have any track times yet |
Re: (DurboDug93)
DurboDug93,
time it yet???? #'s similar to mine..... https://honda-tech.com/forums/images/smilies/emthup.gif |
Re: (Snoflake)
ok heres what i got
97b18b, carfax'd at over 200k miles lovefab shorty t3/t4 57 trim .63 exhaust tial 38mm home made 3" dp/2.5" testpipe and greddy evo catback drag kit intercooler 2" pipes from turbo to i/c, 2.25" from i/c to throttle body greddy type s bov b16 intake manifold gangstered to fit the ls head stealthmode oil kit walbro 255 intank tunertoys 550's uberdata hallman mbc gsr tranny act heavy duty pp and 6 puck unsprung disc with stock flywheel i think thats just about it. my dyno #'s are in my sig, and ill hopefully get track times next weekend |
Re: (blackeg)
Shit... these are all pretty consistant #'s being put down... very nice fellas https://honda-tech.com/forums/images/smilies/emthup.gif
bout a week or 2 ill have some dyno numbers at 10psi, maybe more https://honda-tech.com/forums/images...s/emsmilep.gif i'm just skeptical about 165k miles on my motor.... although the guy up ^^ had 200k so https://honda-tech.com/forums/images...s/emsmileo.gif |
Re: (Thurman_Merman)
my RS has 243K on it but the motor was swaped out for a 97B18B with 80K on it i think im around 95K tho...just doa comp test/leakdown see how the motor is
mine was at less then 4% all the way across the board.... https://honda-tech.com/forums/images/smilies/emthup.gif might turn the boost up some inthe futre since i see so many 14-16psi stock LS's |
Re: LST / LS-T Turbo B18B's... (Snoflake)
any non-VTEC guys with a 2.0L bottom end looking for some serious power i have a serious non-VTEC cylinder head package for sale...click the link in my sig....
nice numbers guys.......... https://honda-tech.com/forums/images/smilies/emthup.gif |
Re: LST / LS-T Turbo B18B's... (non-VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-VTEC »</TD></TR><TR><TD CLASS="quote">any non-VTEC guys with a 2.0L bottom end looking for some serious power i have a serious non-VTEC cylinder head package for sale...click the link in my sig....
nice numbers guys.......... https://honda-tech.com/forums/images/smilies/emthup.gif</TD></TR></TABLE> yea ME>..jsut need pistons for my 85mm block...thinking of running 10:1 comp |
Re: (Snoflake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Snoflake »</TD></TR><TR><TD CLASS="quote">my RS has 243K on it but the motor was swaped out for a 97B18B with 80K on it i think im around 95K tho...just doa comp test/leakdown see how the motor is
mine was at less then 4% all the way across the board.... https://honda-tech.com/forums/images/smilies/emthup.gif might turn the boost up some inthe futre since i see so many 14-16psi stock LS's</TD></TR></TABLE> DAMN!! lol my RS doesnt have that many, just original 165k on motor/chassis. ill turn up the boost to 10psi next weekend and throw it on the dyno when it's cooler out..... god i hate driving in the hot weather, such a pig https://honda-tech.com/forums/images...s/emthdown.gif |
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Thurman_Merman »</TD></TR><TR><TD CLASS="quote">
DAMN!! lol my RS doesnt have that many, just original 165k on motor/chassis. ill turn up the boost to 10psi next weekend and throw it on the dyno when it's cooler out..... god i hate driving in the hot weather, such a pig https://honda-tech.com/forums/images...s/emthdown.gif </TD></TR></TABLE> hey shyt happens...LOL build it, drive it, blow it, fuck it! https://honda-tech.com/forums/images...s/emsmileo.gif |
i'm just skeptical about 165k miles on my motor.... although the guy up ^^ had 200k so https://honda-tech.com/forums/images...s/emsmileo.gif </TD></TR></TABLE> my compression is 188-190 across all 4 and my catchcan stays pretty dry. my motor does burn a little oil, but for some reason its much less now after i put the turbo on |
Re: (blackeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackeg »</TD></TR><TR><TD CLASS="quote">
my compression is 188-190 across all 4 and my catchcan stays pretty dry. my motor does burn a little oil, but for some reason its much less now after i put the turbo on</TD></TR></TABLE> is that witth 5 or 10 turns of the starter? mine was 255 with 10 turns and 190 with 5 turns |
Re: (blackeg)
my compression is 188-190 across all 4 and my catchcan stays pretty dry. my motor does burn a little oil, but for some reason its much less now after i put the turbo on</TD></TR></TABLE> Is that 200k carfax on the car itself, or is it a different motor? LOL and how does one go about gangsta fitting the b16 IM onto there ls https://honda-tech.com/forums/images...s/emsmilep.gif |
Is that 200k carfax on the car itself, or is it a different motor? LOL and how does one go about gangsta fitting the b16 IM onto there ls https://honda-tech.com/forums/images...s/emsmilep.gif </TD></TR></TABLE> Hackinthe flange off and welding a LS one on the mani...hehehe |
I put down 240/207 at about 10 - 11 psi on a stock LS with a 57 trim T3TO4E. My best time was a 12.9 @ 111 on 14" street tires with a 2.1 60'.
Re: (Junglesnake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Junglesnake »</TD></TR><TR><TD CLASS="quote">I put down 240/207 at about 10 - 11 psi on a stock LS with a 57 trim T3TO4E. My best time was a 12.9 @ 111 on 14" street tires with a 2.1 60'. </TD></TR></TABLE>
nice times what chassis??? |
Re: (Snoflake)
Hackinthe flange off and welding a LS one on the mani...hehehe</TD></TR></TABLE> lol cacky smart ass.... ill give it a try this weekend, hopefully my tube of jbweld will do the trick https://honda-tech.com/forums/images/smilies/emthup.gif |
lol cacky smart ass.... ill give it a try this weekend, hopefully my tube of jbweld will do the trick https://honda-tech.com/forums/images/smilies/emthup.gif </TD></TR></TABLE> AutoZone is your friend.... back on track... what Mani's is everyone running?????? i know JG makes the BIG DICK mani for LS's and Blox/skunk2 have one for LS who else???? |
Re: (Snoflake)
what Mani's is everyone running?????? i know JG makes the BIG DICK mani for LS's and Blox/skunk2 have one for LS who else???? </TD></TR></TABLE> prostreetonline is having a sale on blox's. 150 shipped new. i would totally buy one, but ive got some tickets to pay for http://images.honda-tech.com/set1//smile/emcrook.gif . <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Thurman_Merman »</TD></TR><TR><TD CLASS="quote"> Is that 200k carfax on the car itself, or is it a different motor? </TD></TR></TABLE> the carfax is on that motor. (my car is a 97 hx with about 10k more miles than the ls i put in it). something is up though, the head is spotless on the inside, so its prolly been hot tanked. when i had the oil pan off, it was dirty as hell, so im assuming the block has never been touched. it is possible my valve seals were not replaced after the tanking, hence my oil burning. i also pull great vacuum, 22-23 at idle once warm and about 26-28 when i am cruising and let off the gas <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Snoflake »</TD></TR><TR><TD CLASS="quote"> is that witth 5 or 10 turns of the starter? mine was 255 with 10 turns and 190 with 5 turns</TD></TR></TABLE> this was at normal operating temp, throttle plate wide open, 6 turns of the motor. this is how ive been doing it for a few years. |
Re: (blackeg)
prostreetonline is having a sale on blox's. 150 shipped new. i would totally buy one, but ive got some tickets to pay for http://images.honda-tech.com/set1//smile/emcrook.gif . this was at normal operating temp, throttle plate wide open, 6 turns of the motor. this is how ive been doing it for a few years.</TD></TR></TABLE> might have to check that out... i ask kuz a lot of peeps do 5-6 and techs at HONDA say 10 |
Golden eagle sleeved 84.5mm ls block
Obx intake manifold(type r repica) sfp race manifold crower dual springs(soon to be 404's!!!) mild p&p(3 angle valve job) t3/t04e .63 ar hot side 60 trim compressor 3" downpipe to 3" straight pipe aem ems with 3.5 bar map and aem wideband custom 2.5" charge pipes spearco 28.5x8x3 tial 38mm wastegate Tuned by Tim Switzer to 373whp and 290 wtq on 18psi on pump gas with 11.8 degrees of timing advance on a 90 degree day!!! |
My setup:
94 Integra LS 81.5mm GE block guarded JE SRP 10.5:1 pistons/Eagle rods Head port and polished w/ Crower valve train Crower 404 cams AEM cam gears (I+4*, E-0) Drag kit w/Tial 35mm WG t3/t04e turbo 2.5" DP to 2.36" DP back HKS SSQV bov RC 550's GSR tranny w/Quaife LSD Exedy Organic racing clutch and ProLite FW Motor built by me, Uberdata tuned by me:D My fastest run so far is 12.71@106 on slicks on 6psi..... Here is my vid...http://thumbs.streetfire.net/AE5323E...0F7685FED2.jpgHere is a video of my second run No dyno's yet, increasing the boost to 10psi this week and getting her on the rollers soon! Modified by nicklk at 11:39 PM 7/29/2005 |
Re: (Snoflake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Snoflake »</TD></TR><TR><TD CLASS="quote">DurboDug93,
time it yet???? #'s similar to mine..... https://honda-tech.com/forums/images/smilies/emthup.gif </TD></TR></TABLE> No track times yet. I need to buy some drag radials or slicks first. Plus im on stock suspension https://honda-tech.com/forums/images...s/emthdown.gif <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nicklk »</TD></TR><TR><TD CLASS="quote">No dyno's yet, increasing the boost to 10psi this week and getting her on the rollers soon!</TD></TR></TABLE> Yeah man, you need to get that thing on the dyno. Im interested to see what gains you will get with those cams https://honda-tech.com/forums/images/smilies/emthup.gif |
Re: (DurboDug93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DurboDug93 »</TD></TR><TR><TD CLASS="quote">
No track times yet. I need to buy some drag radials or slicks first. Plus im on stock suspension https://honda-tech.com/forums/images...s/emthdown.gif </TD></TR></TABLE> dont mock the stock shyt my homie ran 11.3 in a full weight GSR with 365whp slick down |
