LSD or 12 psi
Old Jan 24, 2002 | 10:57 PM
CM-R's Avatar
Default LSD or 12 psi
Should i just go spend my money on a quaife lsd or go and get v-afc, RC 370cc injectors with RC wire clips, 6:1 vortech disk, and dyno time...
Thanks in advance.....
Old Jan 24, 2002 | 11:16 PM
DIRep972's Avatar
Smarter than you
Default Re: LSD or 12 psi (CM-R)
whats gonna benifit u more now/long run
Old Jan 24, 2002 | 11:23 PM
CM-R's Avatar
Default Re: LSD or 12 psi (DIRep972)
i wanted the quaife lsd cause i dont have traction for crap at 7psi with my drag 3 gsr....but i think i can learn how to control and feather the gas....so i might just upgrade to 12 psi....any other suggestions??
Old Jan 24, 2002 | 11:36 PM
threatcon13's Avatar
New User
lsd..more power is useless if you cant get it to the ground.
Old Jan 24, 2002 | 11:45 PM
HaUTSaauce's Avatar
New User
go lsd
Old Jan 25, 2002 | 12:15 AM
austrian type-R's Avatar
Default Re: LSD or 12 psi (HaUTSaauce)
12psi on stock bottom end?
Old Jan 25, 2002 | 12:26 AM
01geeser's Avatar
New User
Default Re: LSD or 12 psi (austrian ITR)
go for the lsd....if you plan on going standalone later ur gonna have to sell all that that stuff later anyways.
Old Jan 25, 2002 | 09:22 AM
CM-R's Avatar
Default Re: LSD or 12 psi (01geeser)
You guys are right....i'm going to go with LSD.....Has any of you guys had experience with Quaife LSD? And are able to just drop the clucth at like 5000 RPM and have full traction or do i have to still use the slipping technique??
Thanks...
Old Jan 25, 2002 | 09:26 AM
Finest's Avatar
Well, instead of spinning one wheel...you'll be spinning BOTH wheels! Invest in some stickier tires or slicks just for the tracks.
Old Jan 25, 2002 | 09:38 AM
GSRwBOOST's Avatar
Default Re: LSD or 12 psi (Prelude_RCR)
I drop the clutch at 3k on the street... turbo spools and the tires break loose in first second and bark into third and the car rockets...
i have the quaife and better tires... and still spin.. can't imagine one tire at 10-12 or even 14psi.
just remember w/ betetr tires and an lsd you'll be spinning the tires as you pass them....
Old Jan 25, 2002 | 09:40 AM
CM-R's Avatar
Ohh ok i see....i always thought that i would get total traction with LSD....i guess i do need to get hondata stage 3b and use launch control....will bfgoodrich drag radials fit on 14 inch steelies??
Old Jan 25, 2002 | 09:55 AM
bruthaboost's Avatar
I have a na (waiting for time to install turbo) ls/vtec (20 over) and if I drop at 3500-4k my tires spin even with the quiafe and radius rods.
95civhb
Feb 24, 2010 02:39 PM
BB4-Japanpower
Apr 24, 2006 03:52 AM
shadowz
Apr 11, 2004 08:59 AM
crj_lll
Dec 16, 2003 01:24 PM
austrian type-R
Aug 14, 2003 04:21 AM
