LS worth it?
Old May 13, 2002 | 03:20 AM
D16Z6racing's Avatar
Default LS worth it?
Full interals were rebuilt with JE Pistons, Crower Rods, Ferra Valves, P&P, bored throttle body and intake manifold. More stuff just can't remember what. Pretty much everything was done. Comp. is 8:5.1. Ready for turbo! No tranny, flywheel, clutch, axels, ecu. Wants $2500. Worth it?
Drag 3 kit. Just rebuilt turbo. All guages inluded and their Apexi gauges. Exhaust temp gauge is hooked up to exhuast manifold. Wants $2000. Worth it?
Lap top computer w/ Windows system and all accessories to run electromotive. Wants $700. Worth it?
Or $5000 for all?
Old May 13, 2002 | 05:09 AM
Finest's Avatar
Default Re: LS worth it? (buster13)
Engine: yes
Turbo kit: No
I would check the compression on that motor. Is it from the same seller? If so, how did he blow his turbo, but not his motor? Seriously check into that. I wouldn't trust a rebuilt turbo, unless I send it off myself to a reputable turbo rebuilder. If the motor checks out good, then it's a steal!
Old May 13, 2002 | 07:34 AM
DA666's Avatar
Default Re: LS worth it? (Prelude_RCR)
standalone wiith a laptop to run it for 700? thats cheap....hondata is 545 untuned without a laptop and stage 2b......do u see the relevence?
Old May 14, 2002 | 01:43 AM
Default Re: LS worth it? (T3T4DA6)
All from the same seller. Turbo was rebuilt becasue bearings were loose. It was rebuilt by Turbotectnics in Tacoma, WA. All parts have no more than 5000 miles on them. Plus the motor comes w/ another head.
Old May 14, 2002 | 04:40 AM
Finest's Avatar
Sounds good. Just get a copy of the rebuild reciept in case something "happens", and you'll be good to go. Good luck.
DJ KENNY DEKX
Apr 21, 2010 07:08 AM
hiphop23j
Nov 10, 2007 06:48 PM
tegda
May 25, 2007 10:14 PM
b18c1tcivic90
Dec 11, 2004 07:40 AM
JDMallTHEway
Oct 20, 2004 08:22 PM
