LS VTEC w/ N02
Old Mar 31, 2014 | 07:00 AM
Garrett Chaney's Avatar
Icon2 LS VTEC w/ N02
I have a B18b1 bottom end, b16 head, eagle H beam rods so far, still looking into pistons, want to run high compression 12-12.5 :1, i think im going to get a set of wiseco's pistons, my main question is do i have to sleeve the block? or can i just have 1mm taken out of the stock sleeves and run an 82mm piston? looking at running a 75 shot, (wet). anyone has run this combo before? how did you set your bottom end up?? t
Old Mar 31, 2014 | 07:09 AM
hardcore97's Avatar
Default Re: LS VTEC w/ N02
I don't know of anyone spraying no2 I'm their honda...
Old Mar 31, 2014 | 07:46 AM
ballistic1350's Avatar
Lol you know he means N2O
Old Mar 31, 2014 | 08:22 AM
gc8dc95's Avatar
I don't see needing sleeves for 1mm over and a 75 shot. Depends on what the future holds.
Old Mar 31, 2014 | 12:29 PM
wantboost's Avatar
Who is Mr Robot?
What fuel are you using? you'll do well to run 12.5:1 compression on 93, with or without nitrous. detonation will be a serious and constant issue. it won't be so bad on spray because the nitrous supplies its own oxygen, ups octane and cools the intake charge.
methanol injection might be a good enough idea for driving off the bottle, as it too raises octane a bit and cools the intake charge.
lucava05
Nov 1, 2008 01:49 AM
jamescb77
Apr 1, 2007 10:25 PM
shazbot
40
Oct 5, 2004 10:15 AM
Modifiedinteg
Nov 27, 2003 05:27 PM
HarryB
Jun 19, 2002 04:56 PM
