LS/vtec turbo whit b16a head ?
ok i got this part but not instal yet
b16 head
edelbrok victor x manifold
Aem fuel Rail
B & M Fuel presure regulator
valve spec
intake Valve Specifications:
- Head Diameter: 33MM
- Stem Diameter: 5.5MM
- Overall Length: 102.5MM
- Tip Diameter: 2.5MM
- BLACK NITRIDE FLAT HEAD
Exhaust Valve Specifications:
- Head Diameter: 28MM
Cams EBay
SPECIFICATIONS ON CAMS:
PRIME LOBE
CENTERLINE - 16.05 BTDC
INTAKE: Duration: 237.17 @ 0.060 INCHES Lift: 0.5583 INCHES
EXHAUST: Duration: 256 @ 0.050 INCHES Lift: 0.494 INCHES
Aerospeed sproket
honda intake manifold gasket
Block
B18a
stock rods
pistons ebay low compresion http://cgi.ebay.com/ebaymotors...h=006
block guard
my ?
whit this setup can run safe on 350 320 hp or the head is very altered sorry for my ingls
b16 head
Aem fuel Rail
valve spec
Cams EBay
PRIME LOBE
Aerospeed sproket
Block
B18a
stock rods
block guard
my ?
