ls vtec turbo question(please look)
Old May 14, 2003 | 12:44 AM
sloef's Avatar
Default ls vtec turbo question(please look)
helped built a motor for a friend of mine.the setup is as follows......b16 2nd gen head, ctr intake,itr exhaust ,b18a bottom with .5m over pistons je 9 to1 ,ls crank,crower rods and cometic headgasket..................if you guys could maybe tell me what kind of compression numbers should be looking at. thanks!
Old May 14, 2003 | 05:44 AM
GEN2TEG's Avatar
Default Re: ls vtec turbo question(please look) (sloef)
If im not mistaken from what i rmember with the b16 head your adding about .3 points of compression.
Old May 14, 2003 | 06:14 AM
Scott - 93HB Si's Avatar
Default Re: ls vtec turbo question(please look) (GEN2TEG)
Gen 2 is right....I just did the same thing and my compression is now 9.3:1
Old May 14, 2003 | 07:37 PM
sloef's Avatar
well thanks i kinda know it's going to be around 9.2,3 to 1 . i did a compression test and came up with 175 psi. across the board cyl.1-4. what do you guys think of these numbers.
Old May 14, 2003 | 07:52 PM
intekragsr's Avatar
numbers look fine. I was told on my last lsvtec numbers should be 160ish.
Old May 14, 2003 | 10:54 PM
sloef's Avatar
Default Re: ls vtec turbo question(please look) (intekragsr)
i'm glad to hear that those numbers look good .....anybody else have any opinions please keep them coming.
brandonschmidt
Dec 18, 2009 08:05 PM
SpoolnByYou
Nov 21, 2006 03:10 PM
getnasty
Mar 11, 2005 04:33 PM
B_1_8_hatch
Nov 20, 2003 07:52 PM
underpressure02
Sep 8, 2003 08:20 AM
