Correct compression for ls/vtec???
Old Dec 18, 2009 | 04:31 PM
brandonschmidt's Avatar
Default Correct compression for ls/vtec???
Im running a b18b block bored .5 over,
B16a2 head,
PR3 pistons,
CTR cams....
I'm getting 200psi across the board warm under full throttle.
And 210psi during a leak down test.
Old Dec 18, 2009 | 05:10 PM
racebum's Avatar
Default Re: Correct compression for ls/vtec???
B16a2 head,
PR3 pistons,
CTR cams....
this is a statement
where is the question?
Old Dec 18, 2009 | 05:12 PM
Is this the correct compression for ls/vtec???
Old Dec 18, 2009 | 05:17 PM
jordaninu's Avatar
yeah that sounds about right
Old Dec 18, 2009 | 05:24 PM
Dogginator's Avatar
Daisy... Daisy...
Measured compression is very much dependent on the gauge. Consistency is what you seek.
Old Dec 18, 2009 | 06:57 PM
shiftmx179's Avatar
Yes those compression numbers are ok for that setup. Like Dogginator said you want all four cylinders to be close and consistent with eachother.
Old Dec 18, 2009 | 08:05 PM
Ok, thank you everyone.
olskoolhatchy
May 7, 2008 12:56 AM
olskoolhatchy
May 6, 2008 03:28 PM
SpoolnByYou
Nov 21, 2006 03:10 PM
dwn4cause
Dec 22, 2004 07:58 AM
