Ls/Vtec turbo freeze plug question?
Old Aug 22, 2009 | 11:45 AM
Mugencrxsir1's Avatar
Default Ls/Vtec turbo freeze plug question?
Hey guys I've been away for a while and I can't for the life of me figure out what these ports are for? What size and thread are they, it's a B18a block, and since I'm use to dealing with Vtec blocks and they look different I'm lost!
I'm assuming it's feeding into the oil jacket as they are open ended...
Thanks for your patience and help fellas!
Old Aug 22, 2009 | 12:30 PM
Turbo-LS's Avatar
Default Re: Ls/Vtec turbo freeze plug question?
This is an older LS block, the one on the left is for oil temp sensor. the DA integra had one. i forget what the hole on the right is for.
Old Aug 22, 2009 | 03:01 PM
Cyphear's Avatar
Not oil pressure?? That's oil pressure on a B18B.
The one on the right may be where the knock sensor goes (on B-series w/ knock sensors), but i'm not sure.
Old Aug 23, 2009 | 07:36 AM
Turbo-LS's Avatar
No oil pressure is 1/8 npt and its not on the plug on the block its on the block its self like all b series engines. Also the top right plug is not for knock sensor. knock sensor doesnt come on b18a/b engines and its also closer to the top of the block as detonation occurs between the head and block not down that far which would be where the crank journals are
out of the three hooles shown the one on the bottom left that seems like its plugged from the pic is for the oil pressure sensor. the one on the left is for oil temp sensor for DA integras and the one on the top right im not sure of. i believe there is just a plug that goes in there not a sensor.
Old Aug 23, 2009 | 08:02 AM
slowboy90's Avatar
if i am not mistaken the thread is a m28
Old Aug 23, 2009 | 03:49 PM
Thanks for the help, anyone else have any guesses?
If it helps any here is my first gen b16 block for referrences... But since I've never dealt with non-vtec's before I'm kind of lost...
Thanks guys,
Anthony
Old Aug 23, 2009 | 07:27 PM
Turbo-LS's Avatar
yeah on the b16 block you have in that pic the sensor with the two prongs and green on it that one goes into the plug hole you have on the left side in your pic and the hole on the right top should just be plugged
Old Aug 23, 2009 | 09:24 PM
redtegra's Avatar
the top right hole is for the green two prong obd0 ECT switch. the one on the left with the big nut is oil temp and the bottom right is the oil pressure sensor.
Old Aug 24, 2009 | 06:18 AM
Thanks Guys, does everyone else agree with Turbo-ls and Redtegra?
Thanks again for the help!
Anthony
Old Aug 24, 2009 | 06:21 AM
Any idea what size and thread that hole would be? The reason I'm confused as they are totally different sizes from the vtec block...
Thanks,
Old Aug 24, 2009 | 02:17 PM
Cyphear's Avatar
This may help...
http://www.g2ic.com/forums/showthrea...65#post1909965
This is the part that may get confusing.
There are 3 sensors on the back of the block of the B18A. Oil Temp, Oil Pressure and a coolant fan sensor.
The B18B has one oil sensor installed, the other oil sensor is plugged off with a 32 mm plug, and no coolant fan switch. You need to remove the plug. Where the plug is on the B18A there is an oil sensor with a threaded adapter, you need to re-use that adapter so the sensor can fit. Ok so the 2 oil sensors are hooked up then you can deal with the coolant fan switch. This is where you need the thermostat cover from the B18B, it is identical except for the fact that there is a threaded bung with a radiator fan switch installed. You need to cut your original harness and extend the wire about 8 inches to reach. The coolant sensors are not similar and the original connector will not fit. I wired in the connector from the B18B harness to give it a clean look.
Old Aug 24, 2009 | 02:24 PM
intense4thgen's Avatar
hole is for the fan swich
Old Dec 25, 2009 | 06:39 AM
Anyone know what size hex those freeze plugs are? I think I might be able to swap the b16 plug for the b18a on the left side port...
Thanks,
Anthony
Oct 5, 2010 09:42 AM
kreatekustomz
Sep 30, 2009 11:50 AM
Japankid
Welding / Fabrication
Apr 9, 2009 12:35 PM
dizzyroc88
16
Jul 16, 2006 03:44 PM
93slmdcvcsi
16
Feb 3, 2004 11:58 AM
