LS/Vtec Turbo.. Confused??
Old Mar 25, 2010 | 04:21 PM
iamthefollower's Avatar
Default LS/Vtec Turbo.. Confused??
Ok, so here is the thing, I just did an LS/Vtec Turbo in my car. It was running good, but it was overheating, car ran fine right before pulling the head. Now, I put the head back on and the car was running good, I took it down the road about 3 miles, car started skipping terribly bad. I got the car back to the house and started pulling the head again. Put a new headgasket on it got everything back together again, and it is still skipping. We pulled the plug wires out to see which one is missing and to our suprise it is only running on 1 cylinder?? It is really confusing with this, because when we had the head checked it wasn't warped or nothing. Any ideas, please help me, really wanna get the car running.
Old Mar 25, 2010 | 04:32 PM
fsg231's Avatar
Default Re: LS/Vtec Turbo.. Confused??
check the dizzy..post the link to you build i cant find it anymore bro
Old Mar 25, 2010 | 04:34 PM
OMG B16's Avatar
Do a compression and leakdown test. Im pretty sure your car wouldnt run with one cylinder. The rest might just be weak.
Old Mar 25, 2010 | 05:26 PM
boostedcivicsir's Avatar
Mr. Badwrench
before you napalm the car, these should be tested first.
Old Mar 25, 2010 | 05:47 PM
hybrdthry911's Avatar
was the car tuned?
Old Mar 25, 2010 | 07:16 PM
that's what I thought, but we pulled plug wires 1-3 out and the car never changed the skipping it was doing?? I just don't get why this would start out of the blue?? I mean all I did was put a new headgasket on it and it started acting up?? I will try and get a compression and leakdown test done now. Last time I did one was when I first got the car going and everything.
Old Mar 25, 2010 | 07:18 PM
Originally Posted by hybrdthry911
was the car tuned?
it was about to get taken to a dyno, that's why I was getting the overheating problem it was doing fixed, but it had been tuned with a wideband. Just trying to get this fixed soon so I can get it going again. If I can't then i'm just going to get ready to tear it down and build it... Just would take me awhile to finish everything up.
Old Mar 25, 2010 | 07:19 PM
https://honda-tech.com/forums/forced-induction-16/my-ls-vtec-turbo-setup-2724975/
Old Mar 26, 2010 | 05:53 PM
TEAM ASSASSIN SI's Avatar
i would deff. do a leakdown and comp. test car won;t run on 1 cylinder.
Craigteal11
Sep 17, 2014 08:07 AM
kmac714
May 23, 2010 02:36 PM
cameldong
Apr 20, 2008 04:49 PM
JDM00SI
Jan 17, 2006 04:18 PM
