wastegate problem with a internal to external conversion
Old Apr 22, 2004 | 03:14 PM
yusoslo's Avatar
Default wastegate problem with a internal to external conversion
My turbo was a internal wastegate converted to external before I got it.
Now when I get on it I hear the turbo spool up and then at 3grand POP, something inside the turbo pops and the compressor slowly stops spinning.
now here is the problem I think.....The turbo has no regulator on the backside of it but I think the "flapper" was still left in the turbo.
my setup is a bit off. The turbo mani does not have a flange for a external wastegate so the guy had a flange for the turbine exhaust housing to have 2 seperate pipes.....one for the external wastegate....and one for the downpipe.
so would I have to remove the flapper completely as apposed to most people welding it shut for a mani mounted wastegate???
Old Apr 22, 2004 | 03:18 PM
kpt4321's Avatar
Didn't you already make a post about this? Seriously.
I don't se a flapper in that picture, but you probably should find out if there is one before you go any further.
lurkin' eg
Oct 29, 2007 09:47 AM
olddohc
Jul 29, 2007 11:14 PM
xfletcherxx
Jun 15, 2006 06:22 PM
abmerop18
Jan 27, 2005 08:05 AM
