ls vtec???help
Old Mar 5, 2004 | 03:38 AM
turboITR#704's Avatar
Default ls vtec???help
I put an ls vtec motor together last week, Went to start it and out of that black canister that the pcv valve runs to 4 quarts of oil came rushing out between the block and that black canister,Replaced o-ring and still.So my question would be what would cause that much pressure to build up like that.....Please help....
Old Mar 5, 2004 | 05:44 AM
Rod.'s Avatar
Default Re: ls vtec???help (turboITR#704)
bump
Old Mar 5, 2004 | 05:55 AM
DaveF's Avatar
Default Re: ls vtec???help (redturbocivic)
are you sure you didnt put the headgasket on the wrong way....and did you plug the head?
Old Mar 5, 2004 | 07:50 AM
Default Re: ls vtec???help (Dturbocivic)
Ya, I think I put it on right, Plug head with what? You mean the vtec line.
Old Mar 7, 2004 | 09:11 AM
DaveF's Avatar
you need to put a 1/8 inch plug into the bottom of the head and than have it machined down if it doesnt go in all the way.
if not plugged...this would cause a major oil leak.
Old Mar 7, 2004 | 01:39 PM
TurboR1391's Avatar
Sounds like you forgot to plug the oil port in the head.
pK1spooled
Feb 13, 2005 04:23 AM
SLow-Side
Nov 21, 2004 03:14 PM
tegmaniac
Apr 24, 2003 07:37 PM
VXpride
Jun 13, 2002 05:05 PM
