LS VTEC Boost build
Old Mar 18, 2015 | 04:05 PM
thugsbryan's Avatar
Default LS VTEC Boost build
Hi guys, I building a lsv setup,
B16 head
ITR cams
ITR intake an trottle body
LS block
LS pistons and rods
Arp rod bolts
B20 crank
I'm running a Switzer turbo
Cal I run 15psi safely on this setup?
Old Mar 18, 2015 | 05:20 PM
turbohatch96y7's Avatar
Sure
Old Mar 18, 2015 | 05:56 PM
NotARaCist's Avatar
I never narc'd on nobody!
Default Re: LS VTEC Boost build
You mean a Schwitzer turbo? Which one? There are more than a few of them.
Actually, don't answer that. Just go read the FAQ sticky. We can lead you to water every time you have a question, or we can just teach you were to find it for yourself.
Old Mar 19, 2015 | 05:33 AM
thugsbryan's Avatar
I not sure of the model Switzer, im looking to make 280-320 who, jus wanna make sure the 15psi is safe
Old Mar 19, 2015 | 05:55 AM
Schister66's Avatar
Man U FTW
Boost pressure is irrelevant. Set your goals in terms of horsepower, not PSI
The only time PSI matters is when choosing a MAP sensor - Do you have an upgraded MAP?
Old Mar 19, 2015 | 05:59 AM
thugsbryan's Avatar
ok i understand, yes I have a Gm 3bar map,
Old Mar 19, 2015 | 06:11 AM
Schister66's Avatar
Man U FTW
Then you're good to go. Have a power goal in mind and let your tuner decide when its time to shut it down.
If we knew a little more about the turbo you're using, we could give you a better idea. There are many turbos with the Schwitzer name on it - the one that comes to mind for me is the S256. If this is what you're running, it wont take 15psi to make 320whp....more like 8psi. Again, this is purely speculation...
Old Mar 19, 2015 | 06:18 AM
thugsbryan's Avatar
Oh ok, the reason I can't tell which model turbo I have cause the number on the plate is missing, so I don't know wat model Switzer it is
Old Mar 19, 2015 | 07:25 AM
LightningTeg's Avatar
Community Builder
Take the compressor and turbine housings off and measure the wheels.
Old Mar 19, 2015 | 07:28 AM
thugsbryan's Avatar
Ok
Marc_Smith
Jan 29, 2010 02:49 PM
shocker911
Apr 6, 2009 03:48 PM
drewbie
Nov 4, 2006 08:59 AM
streetrage
Mar 29, 2005 09:26 AM
