LS-V Turbo no vtec when warm
Old Jul 23, 2011 | 08:56 AM
streetej1's Avatar
Default LS-V Turbo no vtec when warm
setup is as follows:
99 gsr head rebuilt with stock internals
99ls b18b1 block
mahle forged pistons
eagle rods
edelbrock victor x
skunk 2 70 mm tb
precision 60-1
cometic headgasket
arp everything
as of the last couple weeks my car is loosing vtec after the car has warmed up. the car has been tuned by scotty at mainstream performance. the oil pump is new and oil pressure is about 60. i have tried swapping the solenoid and pressure switch. ive tried swapping the ecu as well. i also have disable vtec speed check, vtec coolant check, and the vtec pressure switch via crome. the motor only has about 2400 miles on it. i dont think the issue lies with bearings because oil pressure is good. also the compression has been check and is good as well. also i removed the tuned map and reburned it with a base map from phearable and it does the same thing. is there anything else that i have missed that could cause me to be loosing vtec?
Old Jul 23, 2011 | 09:02 AM
ShanghaiOC's Avatar
Default Re: LS-V Turbo no vtec when warm
Have you tried changing the VTEC solenoid itself?
Old Jul 23, 2011 | 09:10 AM
streetej1's Avatar
I did swap my solenoid onto my buddies b16 Rex and it worked fine
Old Jul 23, 2011 | 09:12 AM
sanman000719's Avatar
then it sound like the solenoid is bad to me
Old Jul 23, 2011 | 09:14 AM
streetej1's Avatar
Above post said the solenoid worked fine on my buddies b16 therefore the solenoid is fine
ShanghaiOC's Avatar
Did you try using your buddy's solenoid on your car & let your car get up to temp? If your problem only lies when its warm, you have to recreate the situation with the new part to try. How much oil is in your car, btw? Oil weight, new? The more info you give, the better of a chance HT can help you out
Old Jul 23, 2011 | 10:20 AM
streetej1's Avatar
Oil is Pennzoil 5w30...changed about 100 miles ago with a new k&n oil filter.....oil level is good.....I did try his solenoid and the problem persisted....
Old Jul 23, 2011 | 01:32 PM
civickiller's Avatar
try swap ecu, vtec went out with my ecu
94wip
12
Jun 20, 2024 07:23 PM
MastaFlyMason
Engine Management and Tuning
Jan 25, 2019 07:45 AM
RinzEG6
Oct 14, 2014 03:34 AM
turbogsr11
Jun 3, 2011 02:39 PM
crxfreak1117
Feb 26, 2010 06:47 AM
