ls turbo tuning question
Old Apr 26, 2009 | 09:19 AM
integrals1983's Avatar
Default ls turbo tuning question
i have a 2000 LS that im planning on turbo charging at some point. its going to run on the stock motor, low boost 6-7 psi and im wondering whats a cost effective reliable tuning tool i can use that will keep the car good for a daily driver. a stand alone is out of the question so im thinking more along the lines of a piggyback system. any suggestions would be appreciated, thanks!
Old Apr 26, 2009 | 11:24 AM
blackeg's Avatar
Default Re: ls turbo tuning question
you can get some chip tuning done, probably even get away with a street tune if your really low on funds. crome/uberdata will work for you to get things started. use them to pull out a few degrees timing and make sure the fuel ratios look good. i used both of them for many years.
since your car is a 2000 you will need to convert to obd1
924doorEG
13
Mar 14, 2008 02:35 PM
peacemaker
Oct 25, 2007 02:22 PM
ghostcivic
Jul 19, 2007 03:23 PM
dan's integra
Dec 20, 2005 02:24 PM
nonvtec
Nov 11, 2002 09:38 AM
