LS turbo...problems...LOTS of problems
Old Dec 28, 2006 | 08:42 AM
  #26
yee SERIOUS's Avatar
i'll chime in since you're a vang brother
but anyways, when i had a problem like you're describing, it was because i had the wrong resistor soldered into my ecu, i had to cut the j1 wire to figure this out.
BUT since you still have a CEL after cutting the j1 wire, i'm guessing it's probably something else.
btw, what brand of chips are you using?
Old Dec 28, 2006 | 03:23 PM
  #27
FaceTuned's Avatar
in uberdata you need to manual remove the checksum that means you need to use hexedit and remove the checksum crome unlike uber has a checksum removal when ever burning a rom you must remove the checksum or else youll get a solid cel(limb dick mode). so tell whoevers burning your roms try this and ill bet it works if the ecu's good.
Old Dec 28, 2006 | 07:20 PM
  #28
VRD^suzie's Avatar
Default Re: (FaceTuned)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FaceTuned &raquo;</TD></TR><TR><TD CLASS="quote">in uberdata you need to manual remove the checksum that means you need to use hexedit and remove the checksum crome unlike uber has a checksum removal when ever burning a rom you must remove the checksum or else youll get a solid cel(limb dick mode). so tell whoevers burning your roms try this and ill bet it works if the ecu's good. </TD></TR></TABLE>
o man..thanks for the heads up..i'll diffenetly tell him about this..thanks alot..and blackeg..thanks for the map.. i'll let everyone know how it turns out.thanks for the help everyone.
BIGef
Jul 31, 2013 03:52 AM
the171
Engine Management and Tuning
Mar 7, 2011 07:16 AM
crx6662
11
Mar 26, 2010 08:58 AM
holsetcivic
Mar 4, 2010 07:27 AM
EK k kay
Aug 1, 2006 05:33 PM
