LS Turbo build...
I am working on building a LS turbo set up. I am using a B18A1 block and head. I took apart the LS head to make sure everything looked okay and I removed the rockers, and didnot write down the order in which they go. So I have a problem. I went to see how much new rockers cost and they are 465 dollars, which is way way too much. So my question is Can I use the old rockers, and if so what order should i put them in? If i adjust the valve lash will i be able to reuse them without any problems?
thanks alot for the help.
