ls turbo boost controller question
Old Feb 24, 2006 | 12:47 PM
bigdaddyradde's Avatar
Default ls turbo boost controller question
This summer i would like to turn the boost up on my LS and i was wondering if i have a 7lb extermal wastegate spring and i hook up a boost controller will i be able to boost more than 7lbs. So my question being does the wastegate spring regulate the max boost? Or if i hook a boost controller up and want to boost say 10lbs will i need to get a different spring?
THANKS IN ADVANCE!!!
Old Feb 24, 2006 | 12:57 PM
roll5104life's Avatar
your good with the same spring the boost controler controls the up but if you have a whatever amount spring you just cant go under the # psi your spring is
Old Feb 24, 2006 | 12:59 PM
sneakypete's Avatar
Default Re: ls turbo boost controller question (bigdaddyradde)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigdaddyradde &raquo;</TD></TR><TR><TD CLASS="quote">This summer i would like to turn the boost up on my LS and i was wondering if i have a 7lb extermal wastegate spring and i hook up a boost controller will i be able to boost more than 7lbs. So my question being does the wastegate spring regulate the max boost? Or if i hook a boost controller up and want to boost say 10lbs will i need to get a different spring?
THANKS IN ADVANCE!!!</TD></TR></TABLE>
If you have a 7 lbs spring that will be the lowest amount of boost you can run. Once you get a boost controller you can turn it up to whatever you want.
Old Feb 24, 2006 | 01:09 PM
Default Re: ls turbo boost controller question (sneakypete)
awesome thats exactly what i wanted to hear. i have a turbo xs mbc so tha **** is going on soon
Old Feb 24, 2006 | 02:43 PM
buttsneeze's Avatar
i've heard that when using a boost controller, you can only boost about twice more than what your wastegate spring is rated for........?
Old Feb 24, 2006 | 05:19 PM
sneakypete's Avatar
Default Re: ls turbo boost controller question (buttsneeze)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by buttsneeze &raquo;</TD></TR><TR><TD CLASS="quote">i've heard that when using a boost controller, you can only boost about twice more than what your wastegate spring is rated for........?</TD></TR></TABLE>
Thats what I've heard also, but I had a 7psi spring and I was able to boost 23 psi no problem (dual stage turbo xs). I think that it pertains more to electronic boost controllers.
Old Feb 27, 2006 | 04:50 AM
Integra_drk's Avatar
With just the standard mbc you can boost up to 12 lbs over you wastegate setting.
94sol
Nov 22, 2006 11:00 AM
vg7z
Sep 20, 2006 08:27 PM
Dancing is Forbidden
Feb 16, 2003 08:42 AM
shingles
Jan 24, 2003 01:58 AM
