LS tranny best for FI??
Old Feb 3, 2002 | 05:35 AM
Adampops's Avatar
Default LS tranny best for FI??
I have been reading a lot about turbo guys swapping to an LS tranny so that they stay in boost longer. My question is, would the LS tranny be benificial on on a JRSCed car??
Old Feb 3, 2002 | 08:23 AM
synergy004's Avatar
Default Re: LS tranny best for FI?? (Adampops)
I got a GSR tranny with a KAAZ LSD on my LS. Actually it works pretty good, I think my car would be a lil slower with the LS tranny but then again I would prolly stay in boost a lil bit longer. I say one of the best mods for a N/A LS is a gsr or b16 tranny. IMO
Old Feb 3, 2002 | 09:30 AM
bigTom's Avatar
Default Re: LS tranny best for FI?? (synergy004)
ls tranny will make ur car slower... period
Old Feb 3, 2002 | 09:49 AM
dustin's Avatar
"Staying in boost longer" means you are accelerating slower.
Dustin
Old Feb 3, 2002 | 09:52 AM
Agamemnon's Avatar
New User
Default Re: LS tranny best for FI?? (dustin)
LOL, well put.
Old Feb 3, 2002 | 10:03 AM
PROFILES2000's Avatar
Default Re: LS tranny best for FI?? (Devin)
well in that case! anyone wanna buy an ls trans lol
(the only reason why i got my ls trans was my gsr trans blew misshift and my friend had a wrecked teg and gave it to me for $300 so i took it ) maybe one day ill rebuild the gsr one and put a nice diff in it (hmmmmmm thinkin to myself that doesnt sound liek a bad idea )
Old Feb 3, 2002 | 11:27 AM
threatcon13's Avatar
New User
Default Re: LS tranny best for FI?? (TurboGsR.com)
so many people are misinformed...myself until now as well, thought that the longer gearing would keep you in boost longer hence making u faster
Old Feb 3, 2002 | 11:38 AM
Projekt20's Avatar
You could keep the LS trans and swap in some GSR gears. I don't really know anything about this buy I heard about a guy in Tampa (Rocky if any of you know) that had SFP swap in a 3rd and 4th gear from a GSR trans and ran a 10.2@135 . I'm just letting you know that maybe having the LS trans might not be a total loss.
-Trung
Old Feb 3, 2002 | 12:46 PM
88CRXHybrid's Avatar
Default Re: LS tranny best for FI?? (Projekt20)
the main reason most FI people switch from short geared trannys(GSR or Type R) to LS is because the torque multipler it so high on the short geared trannys that they cant keep the wheels, even slicks, planted. So if you could keep the wheels planted and you didnt run out of gears in the 1/4mile then the shorter the ratio the better. Another thing to consider is gas milage, engine reliability, and top speed. The shorter the gears the higher the revs will be at a particular speed, which will give you worse gas milage. The sustained higher rpm's will also ruin the motor faster.
Old Feb 3, 2002 | 02:38 PM
turbotypeR@SPEC's Avatar
25 Year Member
Default Re: LS tranny best for FI?? (88CRXHybrid)
i am planning on buying an ls tranny mainly because i can get one pretty cheap and if it breaks,i will be out a lot less money than if i broke a r tranny.also,now that i have plenty of power the r gears seam to be way to short.it seams like i have to shift before i pass the 60 ft mark.it also is at to high rpm's on the interstate.
Old Feb 3, 2002 | 03:18 PM
DR. ON POINT's Avatar
Banned
Default Re: LS tranny best for FI?? (turbotypeR)
u should get a LS tranny if u have to put ur car in 5th before the end of the quarter mile
[Modified by On Point EK, 4:19 PM 2/3/2002]
Old Feb 3, 2002 | 06:53 PM
Bnjmn's Avatar
You wouldn't be slower if you are running taller gears...if you were comparing the same gear ratios that would be one thing, but you aren't.
"The real drag racers buy $2300 OS Giken turbo (tall) gear sets." - DrealGSR
Ben
Old Feb 3, 2002 | 06:57 PM
bigTom's Avatar
Default Re: LS tranny best for FI?? (Bnjmn)
well in that case... ur not going fast enough!
Ben
u will be slower if u are running taller gears because with shorter gears u will always be higher a quicker thgough the powerband... and as for real racers buying longer gear ratios... thats just plain bs... i know for a fact most of the fastest honda's out there are not running long ratios
Old Feb 4, 2002 | 02:07 PM
deviant1's Avatar
Default Re: LS tranny best for FI?? (JV)
ttt
Old Feb 5, 2002 | 09:24 PM
Gmedalion's Avatar
Default Re: LS tranny best for FI?? (deviant1)
Would a LS tranny with GSR 3rd and 4th gear work perfect because of the closer gears and than you still have the long LS fifth gear and LS final drive??
Old Feb 5, 2002 | 09:49 PM
Dee's Avatar
Dee
Default Re: LS tranny best for FI?? (Gmedalion)
after I install my LS tranny I'll post the difference in 60ft times and *** dyno recordings...
Some people need to do more research because a lot of Top racers use after market wide ratio gear sets from Quaife, OS Giken, and another company that escapes by beer contaminated memory!
joshgsr95
Dec 30, 2008 02:27 PM
itz_nij
Mar 15, 2004 05:26 PM
94lsboost
Sep 21, 2003 03:30 PM
Billy_goat
Sep 21, 2003 01:40 PM
