Need info onB18C5 turbo!!
wassup! i got rid of my NOS and planning to go force induction on my type-r engine(B18C5)! what's the best performance parts for turbo should i get? i wanna go higher compression and turbo, is this possible?? please help!!!
_______
_______
Re: Need info onB18C5 turbo!! (MUGENTYPER)
hey mugen man just do a search and you will be set free!! i'm new in this post and i found everything out by searching for it first!! so give it a try and im sure you will find the best setup for your application.
Re: Need info onB18C5 turbo!! (gcajnr21)
You wanna go higher compression and turbo
The compression is already very high (10.6:1) and you canīt boost more than 7-8psi SAFE on the stock bottom end until you lower the cr. You want a standalone ECU too for a good setup.
Go with custom or DRAG III kit
