LS-T Build
Old Oct 7, 2013 | 06:34 PM
  #76
wantboost's Avatar
Who is Mr Robot?
Default Re: LS-T Build
the CC stage 5 is a great clutch, it chatters a bit but thats common
Old Oct 7, 2013 | 06:45 PM
  #77
Turbo-LS's Avatar
I ran a comp stage 5 and tore it apart quickly. eBay clutch lasted longer. Comp stage 4 on the other hand holds up really well and with an upgraded pressure plate will hold well
Or get a clutch masters stage 5 high rev version
I love my clutch masters twin
Old Oct 7, 2013 | 06:48 PM
  #78
jarrodsi's Avatar
Thanks guys Im going to go with that clutch and spend the money I woulda saved from buying a twin disk on a better lsd. Im thinking im just going to resurface my flywheel instead of buying a new one. Is that a bad idea??
I'd go with 2000 cc injectors fic or
As well as a itr style intake mani.
340 in tank should be fine.
Im going to use the skunk2 IM and going with the walbro 400lph and ID1300's
Old Oct 8, 2013 | 10:42 AM
  #79
$MIKE$'s Avatar
Sounds great lets see some dyno results!!!!
Which skunk2 IM r u going to use?
Old Oct 8, 2013 | 11:24 AM
  #80
LightningTeg's Avatar
Community Builder
I'm running an ACT XXG6 which is rated to 490 ft-lbs iirc.
Old Oct 9, 2013 | 12:02 PM
  #81
jarrodsi's Avatar
Im going to run the skunk 2 pro series with a 70mm throttle body. Im hoping to have my build done by this spring so I will post the dyno chart and numbers and soon as I get them. Thanks everyone for being so much and giving me your input. Im going to run the stage 5 competition clutch and probably just resurface my flywheel and also use the MFactory lsd. I think that's all im going to do with my tranny for right now. I want my done and running.
sadatiel
Apr 6, 2015 03:03 PM
Boostedld9
Oct 8, 2014 06:49 PM
jarrodsi
Aug 20, 2013 03:25 AM
acura_b18c1
Aug 22, 2006 09:20 PM
preylude97sh
Oct 21, 2004 02:09 PM
