Boostin b16a
Old Oct 6, 2013 | 02:30 PM
Lezone's Avatar
Default Boostin b16a
Hey guys. I am new to this forum. I would like to have ur opinions on boosting a b16a engine. I also would like to know how much it would cost. I currently driving a 95 eg hatch si with a b16a n was lookin for a little boosting. Thanks
Old Oct 6, 2013 | 04:35 PM
DX_JDM_HATCH's Avatar
Default Re: Boostin b16a
You should read through all this first
https://honda-tech.com/forums/forced-induction-16/%2A%2A%2Aforced-induction-forum-faq%2A%2A%2A-1024174/
Old Oct 7, 2013 | 02:46 AM
Freemananana's Avatar
It's a great idea. Not the best motor, but it will work.
Don't cheap out on the turbo kit. Going to cost at least $2,000 to piece it together.
He already pointed you to the FAQs.
Old Oct 7, 2013 | 11:20 AM
rsangha13's Avatar
Just wondering why you don't think it's a good motor to work with?
Old Oct 7, 2013 | 11:40 AM
TheShodan's Avatar
Moderator
A B16A is fine. if matched with the right sized turbo, they can be VERY beastly...
Old Oct 7, 2013 | 11:58 AM
Uncle Dave's Avatar
Im with you I think there a good engine when the turbo setup is matched to the engine.
Old Oct 7, 2013 | 02:30 PM
rsangha13's Avatar
Yea i knew that haha I was just wondering on the opinion of why they thought it wasn't
Old Oct 7, 2013 | 04:18 PM
SiRCiviC94's Avatar
Tuning and free flowing will make it a machine. 4 grand proper clutch, trans, studs etc and good kit some slicks. Set a budget
Old Oct 8, 2013 | 06:13 PM
Lezone's Avatar
so i been thinking and i want to slowly build my car. Can i boost a stock b16 first then slowly work on the internals? I pretty new to this so i dont kno much. If i boost b16, should i get new ecu? tuned? etc..? or i can wait out on that
Old Oct 8, 2013 | 06:40 PM
wantboost's Avatar
Who is Mr Robot?
you can't slowly work on the internals.... unless you have a spare block w/ crank you have to pull the motor and do pistons and rods at once.
This isn't a lego set
Old Oct 9, 2013 | 03:05 AM
I agree with both of you, the B16A is a great motor to boost. The compression gives it better out of boost qualities and it makes good power with less boost. It's just not what most people do, that was more my point.
And wantboost kind of nailed it on the lego set. Unless you mean slowly buying the internals and assembling it at once. But you can't put like one new piston on cylinder one. Then next month do another cylinder. Then do a rod here. It's not like replacing your driver seat and saving up for the passenger side.
Old Oct 9, 2013 | 07:04 AM
Lezone's Avatar
I think everyone's confused on what I'm Tryin to say. I mean is it possible to boost a stock engine b16. N if so, do i need to do anything else? Then later have internals upgraded. Or is it best to do it all at the same time?
Old Oct 9, 2013 | 07:43 AM
justYncredible's Avatar
It's wU to the sOLdiEr!
You can boost any motor stock...this has been covers numerous times
Old Oct 9, 2013 | 08:10 AM
Yep.
Stock B16A is good for 300 HP on a good tune. I'm shooting for 250~280 on mine. Internals (pistons, rods, ect) bump that up considerably. It has been covered though. You can boost your stock B16A, rebuild it's internals later, retune and reboost for more power.
Old Oct 9, 2013 | 11:24 AM
Lezone's Avatar
Thanks. Just worried about messin with the engine. Pretty new at this.. Just seekin advice. Any advice on turbo kits u guys prefer?
Old Oct 9, 2013 | 12:08 PM
TheShodan's Avatar
Moderator
Mmmm. Really depends upon your budget, as there are lots of "kit" choices. Some come with the option of well-matched turbochargers for your needs. Others don't. The cool part is for the good companies that use a T3 or T25 flange for the turbocharger, you can get the turbo from another source, and in many circumstances bolt right up. It all depends upon what you're trying to spend.. Because they don't come with Injectors, Clutch, Flywheel, pumps, or Engine mangement. Plan over $3K for this.
Old Oct 9, 2013 | 12:16 PM
Probably more if you go with a good tuning software and a kit from somewhere. Kits run $2K themselves, S300 is $600, getting someone to tune is $500 (just a rough estimate) and that doesn't include anything he mentioned really. You can go crome and save the $600, but that will buy a new clutch kit. Still have injectors and anything the kit is missing. Wideband, radiator swaps, matching the downpipe to your exhaust, upgraded exhaust, catch can, map sensor, spark plugs, boost controller, boost/oil pressure gauges, traction bar (for downpipe clearance if you need it), converting to OBD1 (if OBD0), the list goes on and on.
Definitely read up, I'll post a decent write up:
https://honda-tech.com/forums/forced-induction-16/complete-how-turbocharge-your-honda-rep-ing-hypnotik-speed-1263795/
Pretty sure that's from the FAQs. But that's one of my favorite write ups, for the pictures mostly.
Old Oct 9, 2013 | 01:37 PM
Lezone's Avatar
Cool. Thanks u guys helped a lot.
eg_ruoner364
Jun 23, 2008 07:34 PM
accord218
Apr 3, 2005 01:50 PM
charjacq
24
Aug 13, 2002 07:57 PM
