ls stock turbo
Old Nov 5, 2003 | 11:05 AM
darkirony's Avatar
Default ls stock turbo
well im doing a custom turbo and finding out more and more info from everyone. i just bought a drag mani with the wastegate on the top. the mani dosent come with a wastegate some im buying one. i dont want to run no more than 8psi on the stock block until i do more work. i was looking at the wastegates online and was curious which one to get. i was thinking the 38mm one but need to know what pressure release setting i should get. plz help
joe
Modified by darkirony at 8:53 PM 11/5/2003
Old Nov 5, 2003 | 11:10 AM
30psi Teg's Avatar
Default Re: ls stock turbo (darkirony)
The TIAL 38mm is probably the best one to get for the money I got mine for around 250 but I have also used Turbonetics Deltagates on a setup like yours with no problem (deltagate cost me 150 used.)
Old Nov 5, 2003 | 11:29 AM
darkirony's Avatar
what spring pressure should i get
Old Nov 5, 2003 | 11:32 AM
quikB18B's Avatar
Default Re: ls stock turbo (30psi Teg)
The 35mm is discountinued so your best bet is the 38mm replacement. I got my 35mm brand new for $175 in FI classifieds, talk to ben @ importparts he can do the 38mm wastegate for like $210
On spring, remmeber you can go higher but no lower, i woudl suggest maybe a .45 bar spring, 6.5 psi, good place to start
Also consider upgrading your mani, i dont trust those drag manifolds
Old Nov 5, 2003 | 11:33 AM
Ri5e's Avatar
Default Re: (darkirony)
7-9 PSI
BlackKnight7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by darkirony &raquo;</TD></TR><TR><TD CLASS="quote">i just bought a drag intake mani with the wastegate on the top. the mani dosent come with a wastegate some im buying one.
Ummm...I am assuming that you meant to say exhuast manifold, and not intake, because the wastegate goes on the exhaust side of the turbo.
Go with a tial if you are going to go external, they make good stuff.
Jake d.
Old Nov 5, 2003 | 11:34 AM
PHiZ's Avatar
Default Re: ls stock turbo (quikB18B)
With a boost controller, manual or electronic; you can only turn UP the boost.
So get a 4PSI spring, and use the BC to up the boost to 8PSI.
Otherwise, if you got an 8psi spring, you could go up, but never down.
-PHiZ
Old Nov 5, 2003 | 11:36 AM
darkirony's Avatar
why dont u trust the drag manis
Old Nov 5, 2003 | 11:39 AM
quikB18B's Avatar
Because they are notorius for cracking, and bost spike. That manifod paired up with the Delagate make a for a shitty team DO asearch you'll see what im talking about.
Old Nov 5, 2003 | 11:54 AM
darkirony's Avatar
well then is it the wastegate or just the mani. what wastegate should i use
Old Nov 5, 2003 | 12:49 PM
1.8t's Avatar
Got my 38mm brand new for $200 shipped.
Old Nov 5, 2003 | 11:12 PM
darkirony's Avatar
ttt
juz10
Apr 5, 2010 02:58 PM
g0tgot
Dec 19, 2008 11:15 AM
civictyper04
Mar 8, 2006 07:17 PM
rocket256
Nov 12, 2004 09:58 PM
Syner-G-Racing LLC
Aug 19, 2004 11:28 PM
