LS or GSR for a turbo setup?
Old Jun 3, 2003 | 09:29 AM
icelarry27's Avatar
Default LS or GSR for a turbo setup?
which motor is better (more reliable and more power) for running a turbo...a GSR or an LS. also, which can handle more boost being stock?
Old Jun 3, 2003 | 09:31 AM
turbod16y8's Avatar
Default Re: LS or GSR for a turbo setup? (icelarry27)
gsr....hands down...
Old Jun 3, 2003 | 09:34 AM
T-sohctec's Avatar
Default Re: LS or GSR for a turbo setup? (turbod16y8)
who the hell voted for the LS?
Old Jun 3, 2003 | 09:49 AM
espanol's Avatar
Default Re: LS or GSR for a turbo setup? (T-sohctec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T-sohctec &raquo;</TD></TR><TR><TD CLASS="quote">who the hell voted for the LS?</TD></TR></TABLE>
I know...ls's suck..
Old Jun 3, 2003 | 10:31 AM
Nyc y0!!!'s Avatar
LS=eh...
Gsr=wheeeeeeeeeeeeeeeeeeeee!!!!!!!!!!!!!!!!!!
Old Jun 3, 2003 | 10:33 AM
J.R.'s Avatar
Default Re: LS or GSR for a turbo setup? (DaBuccaneerFan2)
gsr
Old Jun 3, 2003 | 10:34 AM
J.R.'s Avatar
sorry for the double post
Old Jun 3, 2003 | 10:46 AM
silverkorn's Avatar
GSR
Ls will handle more boost due to lower CR, but you want quality psi not quanity
the higher compression of the gsr will mean more power per psi and also less turbo lag
Old Jun 3, 2003 | 11:03 AM
mamaboy's Avatar
the higher compression will help that turbo spool up faster fo shizzle.....wheeeeeeeee...well when comparing the two similar turbos and trims
Old Jun 3, 2003 | 11:05 AM
bottlefedb18c1's Avatar
Default Re: LS or GSR for a turbo setup? (mamaboy)
GSR
Old Jun 3, 2003 | 11:10 AM
phase12gsr's Avatar
Default Re: LS or GSR for a turbo setup? (bottlefedb18c1)
the LS will be able to handle more boost due to its lower compression ratio, but the GSR will always make more power if the two are at the same boost level.
if you dont plan to build and just want to boost on the stock motor id say LS (even though i voted GSR). ive also noticed that if you compare the two motors stock, the LSs always seem to run better times (probably because of more boost)
Old Jun 3, 2003 | 12:08 PM
icelarry27's Avatar
Default Re: (silverkorn)
thanks
Old Jun 3, 2003 | 12:29 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: (icelarry27)
https://honda-tech.com/zerosearch
This topic has been discussed about 3 zillion times.
I have an LS but a GSR sure would be nice.
Search!
Old Jun 3, 2003 | 01:28 PM
B18C-Turbo Si's Avatar
Default Re: (HybridcivicLS-T)
GSR hands down... many people talk about the B18B handleing more boost, this is true only if you plan on running stock internals...... if you plan on building a quick car with alot of horsepower then GSR built is the only way to go..... and while you are at it get a B16 Head, breaths much better than a GSR head.
Old Jun 3, 2003 | 01:34 PM
silverkorn's Avatar
Default Re: (B18C-Turbo Si)
yes the b16 head flows better but under boost you rather have the gsr head.
the cams have less overlap and the head has less sharp corners which lead to detination
Old Jun 3, 2003 | 02:02 PM
madman604's Avatar
with proper tuning i thing both motors can handle high boost, but the GSR will live longer cuz of better oil control.
not to mention it flows way more than the LS
GSR
Old Jun 3, 2003 | 02:41 PM
patdemps's Avatar
Default Re: (Turbo E)
GSR no doubt.....
Old Jun 3, 2003 | 05:14 PM
TRAY's Avatar
Default Re: (patdemps)
LS...cuz its cheap!
Old Jun 3, 2003 | 05:33 PM
GOLDBERG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C-Turbo Si &raquo;</TD></TR><TR><TD CLASS="quote">GSR hands down... many people talk about the B18B handleing more boost, this is true only if you plan on running stock internals...... if you plan on building a quick car with alot of horsepower then GSR built is the only way to go..... and while you are at it get a B16 Head, breaths much better than a GSR head.</TD></TR></TABLE>just cause the head flows better dont mean it makes more power....look around..how many stock b16's do you see makeing over 300whp on 8-9psi????????????
gsr all the way
Old Jun 3, 2003 | 09:05 PM
viCeVerSa's Avatar
ii plan on getting an ls because gsrs are so damn pricey
i got a question though, how much power can the stock ls block take before i would need to sleeve it,?.....
Old Jun 3, 2003 | 09:59 PM
InTeGrA B18b1's Avatar
Default Re: (viCeVerSa)
turbo the LS then add a b16 head on it
Old Jun 3, 2003 | 10:43 PM
Broken Gearbox's Avatar
Default Re: (InTeGrA B18b1)
gsr.
Old Jun 3, 2003 | 10:47 PM
TURBO B's Avatar
all i have to say for the non believers is CHEEZEFROG
Old Jun 3, 2003 | 11:52 PM
Default Re: (TURBO B)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TURBO B &raquo;</TD></TR><TR><TD CLASS="quote">all i have to say for the non believers is CHEEZEFROG</TD></TR></TABLE>
whose that??
Old Jun 4, 2003 | 01:07 AM
AlLMoToRvOtEr's Avatar
All depends if you are talking about a fully built motor or a stock motor a LS block is capable of making the same power as a GSR just depends on whats inside the block. Really the only difference between the two is just the oil squirters 1 and 2 the GSR crank makes better power at higher RRRRRRRRR's From what I have read and heard the LS crank will only make power up to 8800 RPM, and the GSR will make power way past that.
trooper0641
35
Mar 21, 2004 12:21 PM
xkhalil333x
Aug 19, 2003 11:39 PM
MooreBoost
Oct 16, 2002 03:37 PM
N2X0
Oct 13, 2002 05:01 PM
AznInvasion
Aug 23, 2002 05:13 AM
