Ls Crank in a b18c Dart
Old Oct 11, 2008 | 04:12 PM
rdssk8rcs1's Avatar
Default Ls Crank in a b18c Dart
Is that crank able to drop right into that block or is there machining involved?
Also any opinions on what crank to use in this block with a 20 over bore, gsr head, turbocharged with a power goal of 500 would be greatly appreciated. Thank you
Old Oct 12, 2008 | 07:25 AM
rdssk8rcs1's Avatar
Default Re: Ls Crank in a b18c Dart (rdssk8rcs1)
come on
Old Oct 12, 2008 | 08:19 AM
adam00's Avatar
yes the ls crank is a drop in but you also need ls rods and the oil squirter plugs from ge also it would be a good idea to get the crank micropolished and balanced
and it should be good for your 500hp setup.
Old Oct 12, 2008 | 08:21 AM
VIhondaman's Avatar
that crank will drop right in but, you also have to use the LS rods. check for proper clearance on bearings.
Old Oct 12, 2008 | 03:46 PM
rdssk8rcs1's Avatar
Default Re: Ls Crank in a b18c Dart (VIhondaman)
Thank you very much. I was aware of having to run the rods that are for the crank just was unsure if i was able to run it.
So that would be the best crank to run or is there a better option? As far as factory cranks go?
Thanks again
Old Oct 12, 2008 | 04:33 PM
Eklsv-t's Avatar
im running b20 crank on ls block
Old Oct 12, 2008 | 04:39 PM
adam00's Avatar
Default Re: Ls Crank in a b18c Dart (Eklsv-t)
b20 crank is the same as ls
Old Oct 12, 2008 | 06:40 PM
mrbsponge's Avatar
dont need to plug the squirters, just push the squirter lines down a tad, it will clear.
mines fine. looking for 850+ this year!
Old Oct 13, 2008 | 07:15 AM
Boosted_B_Series's Avatar
Factory honda cranks are balanced very well from the factory.. so there isn't a need to have it balanced.
Old Oct 13, 2008 | 10:29 AM
eg:R's Avatar
Default Re: Ls Crank in a b18c Dart (adam00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adam00 &raquo;</TD></TR><TR><TD CLASS="quote">b20 crank is the same as ls</TD></TR></TABLE>
i thought the b20 crank different. so boring out an ls to 84mm will be EXACTLY like a b20 motor?
Old Oct 13, 2008 | 10:58 AM
Jdmsoles's Avatar
From: Dodgin Cops all Round Ana-Crime to Orange & Sd
so ls crank ls rods gsr pistons would make it a 2.0 or what?? does displacement change ...??
Old Oct 13, 2008 | 04:51 PM
LSTEG96's Avatar
Default Re: (Jdmsoles)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jdmsoles &raquo;</TD></TR><TR><TD CLASS="quote"> so ls crank ls rods gsr pistons would make it a 2.0 or what?? does displacement change ...?? </TD></TR></TABLE>
wow. absolutely not. it would make it an LS w/ higher compression.
does this B18C dart block say b18c on it?
Old Oct 13, 2008 | 04:52 PM
LSTEG96's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eklsv-t &raquo;</TD></TR><TR><TD CLASS="quote">im running b20 crank on ls block</TD></TR></TABLE>
baller!!!!! how much hp did that pick you up?
Lil_savage
Feb 20, 2019 03:19 AM
Rice Is Best
13
Sep 2, 2010 02:10 PM
joedeezy
Oct 18, 2008 02:53 PM
jordan2305
Dec 11, 2007 04:47 PM
BlakeJ53
Sep 4, 2007 03:59 AM
